Author Topic: [GB] GMK Oblivion (Complete)  (Read 462185 times)
Offline ThatsFineThatOne
Re: [GB] GMK Oblivion (95% Complete).
« Reply #350 on: Sat, 25 November 2017, 13:32:15 »
Keycaps arrived at Keyclack on 30th October. Nearly 4 weeks later and my set still hasn’t left...
Offline Traveler
« Reply #351 on: Sat, 25 November 2017, 13:36:02 »
hi so i received the sets and mounted the caps on a kb. i noticed that the ansi Return key and the default (6.25x i think) spacebar sit lower than any other key of their respective  rows. that is , the spacebar key travel distance is smaller than they alt, ctrl etc.  it bottoms out on the same height   , but rests lower. as for the enter key, same thing. it sits actually even lower than the spacebar key compared to the respective row keys. it doesnt feel right when pressed in all the way. travel distance is too small. anyone else has the same issue?
pictures below. as much as it makes sense.
My set looks just fine. I have white alphas though, if that makes any difference. Definitely strange.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #352 on: Sat, 25 November 2017, 13:39:05 »
Caps fit fine here as well. I suspect this is an issue with your stabilizers or so. How is it for other stabilized keys, such as Shift or Backspace?
Offline pitfermi
« Reply #353 on: Sat, 25 November 2017, 13:46:41 »
Yes indeed.the caps are just fine and they fit on my other ajazz ak33 kb just fine. Im trying to swap switches atm. I have everything soldered so i cant change stabs. The backspace position is fine. Same height as the others too. Its just return and spacebar. I suspect switches since stabs look same
Sent from my HTC One M9 using Tapatalk
« Last Edit: Sat, 25 November 2017, 13:51:20 by pitfermi »
Offline Oblotzky
« Reply #354 on: Sat, 25 November 2017, 13:53:16 »
Btw managed to finish my Lightsaver built today. To everyone who's package is still stuck in the system, I'm sorry for the delays, but I hope they arrive safely after all so you can enjoy them as much as I do! Cheers for supporting this group buy, couldn't have this without all of you.
Offline pitfermi
« Reply #355 on: Sun, 26 November 2017, 02:48:15 »
Alright after further investigation i can safely say it's thestabs. Applying extra pressure left and right of the spacebar/return keycap permanently locks the keycap in a lower position. Since the bottom out is the same and the initial height is different, the stab stems force the switch to start at a lower initial position. This, however, is not the case with the backspace key/cap. It might be due to the smaller length. If i mount the spacebar and return by applying pressure only on the middle where the switch itself is then its fine. Stabs came with the b.mini pcb from winkeyless.kr. is there an easy fix for this?
Offline pitfermi
« Reply #356 on: Sun, 26 November 2017, 13:53:26 »
Also, here is the finished product. my first mech kb using mx browns, kbd75 gray case(yes i bought it to match with the caps :D
I love the cherry profile and the type feel is awesome. props to Oblotzky once again.
Offline Oblotzky
« Reply #357 on: Sun, 26 November 2017, 14:16:31 »
Looks great, thanks! Glad you like it :)
Offline fatpolomanjr
« Reply #358 on: Sun, 26 November 2017, 16:29:52 »
This set is amazing. I'd been planning and acquiring matching artisans for months. Can't wait for SA Oblivion to go on my planck.
Some guys keep on saying they believe in Jesus, and keep doing a lot of shameful things.
Current GH Classified Post (LF Arcade Floor, Garbield and CYM Otter and Keyng)
Offline eyedrop
« Reply #359 on: Sun, 26 November 2017, 16:45:00 »
Anyone else in the US still have a "pre-shipment" status?  It has now been this way since 11/16 and I'm starting to think there is a problem.
I am in the same boat.  I got the tracking number from jchan back in 11/16 and it still shows awaiting item.   :(
Offline Nickjames
« Reply #360 on: Sun, 26 November 2017, 18:51:13 »
Same, not sure what's up. Either USPS lost it or they're still scanning packages after the initial pick up?
Offline beamingrobot
  • もうけい
    • monokei
« Reply #361 on: Sun, 26 November 2017, 20:24:40 »
Same, 2 out of 3 orders haven't been picked up? 1 has been delivered so it's very confusing
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
Offline HMK
« Reply #362 on: Mon, 27 November 2017, 01:13:56 »
Keyclack Special. The set looks amazing: the most gorgeous grey I've ever seen.
Thanks for JChan, RAMA, and Oblotzky for this amazing keyboard. :-X
183028-0183030-1
183032-2183034-3
Offline astonlau
« Reply #363 on: Mon, 27 November 2017, 22:28:01 »
Order Status: PROCESSED. I come here to check everyday.
« Last Edit: Mon, 27 November 2017, 22:46:16 by astonlau »
Offline meirish
« Reply #364 on: Tue, 28 November 2017, 06:43:49 »
Put these on last night. Had to fish a bit for all of the right sizes - would love an ‘dox mod kit ;). This will do for now while I wait fo my EXTENT though  :D.
Offline TalkingTree
    • My projects
« Reply #365 on: Tue, 28 November 2017, 07:17:30 »
Soon to be on a keyboard.
Offline oatmicro
« Reply #366 on: Tue, 28 November 2017, 08:11:44 »
Got mine today, guys...it's so amazing.
I'd like to get more but the shipping cost is kinda weird, dunno what's happening.
Offline Nickjames
« Reply #367 on: Tue, 28 November 2017, 08:33:55 »
Mine finally left USPS limbo. I am excited for this Thursday!
Offline online
« Reply #368 on: Tue, 28 November 2017, 10:33:35 »
Mine still in Pre-Shipment... check everyday +1
  • もうけい
    • monokei
« Reply #369 on: Tue, 28 November 2017, 10:42:45 »
same here
http://monokei.co
Offline eyedrop
« Reply #370 on: Tue, 28 November 2017, 12:27:40 »
For what it's worth, mine was just picked up yesterday, to be delivered on Thursday.  It was stuck awaiting item since 11/16.
Offline Atredl
« Reply #371 on: Tue, 28 November 2017, 17:01:36 »
Just wanted to chime in. I was also part of the 11/16 stuck in limbo crowd but now it updated and will be delivered today. :)
Offline MukY
« Reply #372 on: Tue, 28 November 2017, 20:46:25 »
Can we get word on international shipments? I've yet to receive any order slip or shipping confirmation
Offline jchan94
  • Keyclack Inc
  • * Moderator
  • Please email jchan@keyclack.com. PMs are disabled
    • KeyClack
« Reply #373 on: Wed, 29 November 2017, 06:04:25 »
oh man, that looks awesome.
I haven't had time to even open Oblivion for my own eyes since packing them.
To those who still have preshipment.
If you still have it next monday, please email support@keyclack.com cuz that's just a tad too long... :(
Support Email: support@keyclack.com
Did you miss something from us?
- Sign up for our Mailing List: https://eepurl.com/coAJ5r
Offline astonlau
« Reply #374 on: Wed, 29 November 2017, 08:13:14 »
How about people who don’t even have preshipment?
I sent my address to that e-mail last week but it didn’t respond.
Offline Slimcea
« Reply #375 on: Wed, 29 November 2017, 11:25:24 »
Pretty much the same state, my order is Processed, and emails to support have just gone unanswered.
It took me messaging him directly on Reddit to get a response to simply re-provide my address (which was correct in the first place), after which there has simply been radio silence for 5 days. Is it too difficult to provide even just a simple email response on the status?
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #376 on: Wed, 29 November 2017, 16:04:20 »
I just sent out an email to get this resolved
We should have this solved by the end of the week :).
So you are aware what I'm getting:
Left means, your order went through
Right means your label could not be generated due to an address issue.
Offline Slimcea
« Reply #377 on: Wed, 29 November 2017, 18:21:03 »
My status is actually PROCESSED and not FAILED, but I've replied to your email with the address again.
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #378 on: Wed, 29 November 2017, 18:25:43 »
To clarify:
Left means, Your Order is Processed (which is what you see as well)
Failed means, "There's an address issue. I can't generate a label".
You don't see the "failed" part on your side as that's a "my side" thing
Hope that makes sense.
edit: btw, they're separate columns
« Last Edit: Wed, 29 November 2017, 18:30:38 by jchan94 »
Offline Slimcea
« Reply #379 on: Thu, 30 November 2017, 01:34:12 »
To clarify:
Thanks, that makes more sense. Please let me know if my address fails still, although there shouldn't be any issue since this is the address I've actually used to order successfully from you before.
Offline iQunix
« Reply #380 on: Thu, 30 November 2017, 05:18:20 »
Good color!
Offline aboreo
« Reply #381 on: Sat, 02 December 2017, 07:11:47 »
Thank you Oblotzky and Jchan for this awesome keycap.
183361-0
Offline 8megabit
« Reply #382 on: Mon, 04 December 2017, 09:51:53 »
I still have pre-shipment and I have emailed you.
Offline MukY
« Reply #383 on: Mon, 04 December 2017, 20:35:07 »
I still have my order on "PROCESSED" and have emailed Jchan as well. Any update?
« Reply #384 on: Mon, 04 December 2017, 21:03:03 »
Offline robotsokk
« Reply #385 on: Mon, 04 December 2017, 22:58:52 »
Just wanted to post that I successfully received mine last week (it may have come in before that, as I was out of town). Been busy with work, but I'm planning on unwrapping the set and putting it on one of my boards later this week. Thanks for making this set happen :)
@home      @work Swapping out boards... coming soon     wtb
Offline Slimcea
« Reply #386 on: Tue, 05 December 2017, 06:36:05 »
Nope no update at all, and no change in order status. Total radio silence, despite multiple emails to both jchan@keyclack.com or support@keyclack.com. The only time I got a response was after making some noise here earlier, and unfortunately, it's been back to stone cold silence. There's been no feedback if the address I resupplied was successful or not, heck, not even a single simple acknowledgement to any of my emails to him.
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #387 on: Tue, 05 December 2017, 21:30:37 »
the people who haven't gotten shipping confirms will get it shortly as I just finished packing everything :D
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
Re: [GB] GMK Oblivion (Complete)
« Reply #388 on: Tue, 05 December 2017, 22:56:20 »
If you got an email from not my emails, ignore it. thanks.
Offline priyadi
« Reply #389 on: Mon, 11 December 2017, 11:14:11 »
jchan, I still haven't got any shipping confirmation. there are 3 tracking buttons on my order page, but all are still showing "Shipment not yet picked up by DHL". can you give me an update on this?
Boards: Filco TKL+HID Liberation, Infinity 60%, Sentraq S60-X, Whitefox, Ergodox, Planck.
Member of the flat keyboard society.
Keycap manifesto: "Key sets without vendor neutral Super key are worthless"
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #390 on: Mon, 11 December 2017, 11:24:42 »
I emailed it to you last week.chevk your email.
Offline priyadi
« Reply #391 on: Mon, 11 December 2017, 19:36:22 »
I didn't get the email. can you resend the email? thanks.
« Last Edit: Mon, 11 December 2017, 19:38:04 by priyadi »
Offline jchan94
  • Keyclack Inc
  • * Moderator
    • KeyClack
« Reply #392 on: Tue, 12 December 2017, 01:53:56 »
i've bumped the enail thread with the tracking
Offline 8megabit
« Reply #393 on: Wed, 13 December 2017, 09:10:37 »
It's been another week and I still have pre-shipment. I emailed you again two days ago but no answer. Can you please get back to me and sort this out.
Offline Brammm87
« Reply #394 on: Thu, 14 December 2017, 14:18:44 »
My GMK Oblivion left Sao Paulo (for some reason?) on the 30th and hasn't moved since... Remind me never to order **** end of year again.
pls gief bbv2
Offline astonlau
« Reply #395 on: Fri, 15 December 2017, 09:05:08 »
Are those trackings mean “please shut the **** up I already gave you a tracking”?
I was so happy about received pre shipment, until I realized 2 weeks gone and nothing moving forward.
Offline eyedrop
« Reply #396 on: Sat, 16 December 2017, 00:18:43 »
Put GMK Oblivion with grey alphas on a grey TX-CP.  I thought it turned out well.
Thanks Oblotzky for designing the keycap and jchan94 for organizing the GB.   :thumb:
Offline brianjking
  • always carry a towel.
    • @brianjking
« Reply #397 on: Sat, 16 December 2017, 11:36:50 »
Offline 8megabit
« Reply #398 on: Mon, 18 December 2017, 08:12:39 »
It's been yet another week of pre-shipment and still no word. I'm trying to summon Oblotzky here as well, maybe you have some different channel through which you can communicate with jchan. I just want to receive your amazing keycaps which I have waited far too long for.
Offline Oblotzky
« Reply #399 on: Mon, 18 December 2017, 10:08:17 »
Hey, sorry that your set is taking so long. Unfortunately jchan hasn't been responsive to me either...
