Author Topic: Possibly stupid question about GH60 (Satan) PCB  (Read 2474 times)
Offline only1gc
« on: Mon, 01 May 2017, 10:34:53 »
Hey guys,
I bought a GH60 Satan off aliexpress preassembled but it was faulty so I got a new PCB sent to me.
The original one had a reset button to enter bootloader mode but the new PCB has 2 dip switches where the reset button used to be.
What do the dip switches do? Which PCB is newer edition? Thanks!
Re: Possibly stupid question about GH60 (Satan) PCB
« Reply #1 on: Mon, 01 May 2017, 12:26:56 »
Ask the seller you bought it from?
Offline odd
« Reply #2 on: Mon, 01 May 2017, 13:52:16 »
The one with the dip switches is a newer version of the KC60 and quite frankly sucks. The new version you have has no bootloader button because the layout is fixed and the 2 dip switches toggle certain keys on and off (split backspace and split right shift).I think the only way to flash it is to use the ISP port on board but I could be wrong. I would ask for the original GH60 Satan you have and if you cannot get one from the same seller there are plenty of places online to get one for around $25 or less.
