Author Topic: Modding keyboard - switches swap  (Read 1585 times)
Offline phinix
« on: Wed, 03 May 2017, 10:03:34 »
I saw some clips on youtube how people open switches without desoldering them.
Would this be a way to swap switches?
If I get Filco with blues, can I buy lets say greens and swap springs and stems by just opening them like on this clip?
Could I do same thing buying Zealios? Could I swap mx blues with Zealios? I would transfer springs stems and top cover. Would this work?
Re: Modding keyboard - switches swap
« Reply #1 on: Wed, 03 May 2017, 10:08:15 »
You can only open switches if it is PCB mounted (no plate) or if it has a custom plate with notches cut out to allow the tops to be removed.
Standard Filco or other OEM plates don't allow you to open the switches.
Offline phinix
« Reply #2 on: Wed, 03 May 2017, 10:22:23 »
Damn.. I thought Filco are pcb mounted...
