Author Topic: Does this layout exist?  (Read 1836 times)
Offline ChitownM2
« on: Wed, 03 May 2017, 12:42:07 »
Relatively new to the MK game, and I've been searching for a 96 key layout which apparently don't come around very often. In biding my time for lightsaver v3 (which I'll be lucky to get in on) or Kira (which is probably a year away) I began thinking that I really could do without the F row. Basically the same layout as lightsaver but without that top row of keys so you would end up with ~80 keys but you would still have a numpad and arrows so it would be unlike any 75% or 84 key layout that I've come across.
So....does this layout exist and I just haven't found it yet or is this something new?
Offline xondat
  • i'm not a star
Re: Does this layout exist?
« Reply #1 on: Wed, 03 May 2017, 12:44:19 »
Yes - commonly known as a 78 key. You should check out rozakiin's UK78.
Offline ChitownM2
« Reply #2 on: Wed, 03 May 2017, 13:07:36 »
That's exactly what I'm looking for. Plus it looks like it might actually happen soon which is a huge plus since I think my chances of getting a lightsaver aren't good :).
Are there any other particularly popular 78 key builds from the past that I could seek out on the secondary market?
« Reply #3 on: Sat, 06 May 2017, 19:34:13 »
redscarf made one. I'm bummed I missed out on that because I really like the layout.
looks like theres also the TK78 https://geekhack.org/index.php?topic=81693 not sure of the status of that though
« Last Edit: Sat, 06 May 2017, 19:39:16 by dorkvader »
