Author Topic: Zealencios ping  (Read 4750 times)
Offline Ales00322
Zealencios ping
« on: Wed, 03 May 2017, 14:18:31 »
I installed some zealencios last night and have noticed a high pitch ping every time my finger even touches a keycap. Is there a way I can avoid this or is this just an effect Zealencios have? I'm using GMK keycaps.
Offline Sneaky Potato
  • Gunslinger
Re: Zealencios ping
« Reply #1 on: Wed, 03 May 2017, 14:35:08 »
Lubing is the best way to quiet down the ping.
Offline AlexG
Re: Zealencios ping
« Reply #2 on: Wed, 03 May 2017, 14:40:40 »
Had to make another account as I miffed up my username. Why would lubing help when i don't get the ping without the zealencios installed?
Offline Dreamre
    • kbdlife
Re: Zealencios ping
« Reply #3 on: Fri, 12 May 2017, 14:06:31 »
What keyboard do you have?
Offline Targa-TV
Re: Zealencios ping
« Reply #4 on: Fri, 12 May 2017, 14:59:16 »
I laughed so f hard reading the title. Now even zealencios ping. oh boy I'm having too much fun.
I wonder if summer 2017 is going to be the 'summer of ping 2.0 the vendetta'. That sounds like a blast.
BTW OP, I recommend dampening material under the case and between the case and the metal plate. If your metal plate want to collaborate it will quieten down. Good luck o7
« Last Edit: Sun, 14 May 2017, 03:28:13 by Targa-TV »
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline MajorKoos
  • 1 life please. Extra large.
Re: Zealencios ping
« Reply #5 on: Fri, 12 May 2017, 19:37:36 »
BTW OP, I recommend dampening material under the case and between the case and the metal plate. If your metal plate want to collaborate it will quieten down, if it's like mine it will give you the middle finger and keeping those angels singing all over the board. Good luck o7
I think it's more a case of the keys are so quiet with Zealencios that the loudest part of the switch becomes that metal leaf.
I'm experiencing similar issues with my earlier generation Zealios.
Lubrication helps somewhat.
Offline hapakey
Re: Zealencios ping
« Reply #6 on: Fri, 26 May 2017, 13:26:33 »
Ping!
