Author Topic: What Board is This?  (Read 2970 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
What Board is This?
« on: Thu, 04 May 2017, 15:32:26 »
I need this ASAP.
Offline xondat
  • i'm not a star
Re: What Board is This?
« Reply #1 on: Thu, 04 May 2017, 15:35:23 »
« Reply #3 on: Thu, 04 May 2017, 15:38:23 »
Code: [Select]
https://massdrop-s3.imgix.net/product-images/sentraq-60-diy-keyboard-kit/MD-25143_20170110112846_fd8d7dc24e06ada5.jpg?auto=format&fm=jpg&fit=crop&w=425&max-h=700&dpr=1
always remember kids....check those image links for pertinent information :thumb:
Offline OnTheBrink
    • Wired In Store
« Reply #4 on: Thu, 04 May 2017, 15:59:04 »
The amount of love I have for people I don't know based on the replies in this thread is borderline creepy.
Will this puppy fit a Poker 3 RGB? Sorry if it's stated I'm walking right now and it's easier to type. Too excited to wait. Need to buy
« Reply #5 on: Thu, 04 May 2017, 16:20:31 »
It's a poker style case, so yes.
Offline OnTheBrink
    • Wired In Store
« Reply #6 on: Thu, 04 May 2017, 16:35:18 »
Do you think the lighting built into the RGB Pok3r will be enough or is this case made to install additional lighting in the acrylic part?
EDIT: Never mind, I see that it's made for the PCB with under glow.
« Last Edit: Thu, 04 May 2017, 16:45:38 by OnTheBrink »
Offline xondat
  • i'm not a star
« Reply #7 on: Thu, 04 May 2017, 19:00:54 »
Will the case fit the Poker 3 RGB PCB? Yes. Not sure what you mean otherwise?
