Author Topic: Where does one purchase JTK keycaps?  (Read 11804 times)
Offline Encabulator
« on: Thu, 04 May 2017, 23:03:35 »
Looking for some nice abs keycaps that won't break the bank and saw jtk recently mentioned. Are they still in production? Where can I purchase them if so?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Re: Where does one purchase JTK keycaps?
« Reply #1 on: Thu, 04 May 2017, 23:06:27 »
http://www.keypop.net/category/keyboard-sets
5th result in google searching your exact thread title  ::)
Edit: I see mostly sold out though.  :-\
« Last Edit: Thu, 04 May 2017, 23:08:26 by SpAmRaY »
Offline Encabulator
« Reply #2 on: Thu, 04 May 2017, 23:06:59 »
Solved, originative.
Offline nmur
  • ಠ_ಠ
« Reply #3 on: Thu, 04 May 2017, 23:07:08 »
Offline Encabulator
« Reply #4 on: Thu, 04 May 2017, 23:11:16 »
What is the exact thickness of of JTK? I'm guessing 1.5
« Reply #5 on: Thu, 04 May 2017, 23:29:18 »
From what I just measured 1.5-1.6 with 1.56 being the most common thickness.
Offline Encabulator
« Reply #6 on: Thu, 04 May 2017, 23:32:28 »
Damn, I gotta get those some time soon.
« Reply #7 on: Thu, 04 May 2017, 23:35:08 »
They'll probably be cheaper than GMK but the GMK sets I have feel higher quality and have better legends. However, I do have the PoW JTK set and I know they've been working on changing the legends since then.
Offline xondat
  • i'm not a star
« Reply #8 on: Fri, 05 May 2017, 11:12:53 »
Definitely the best "bang for you buck" set anyone could buy. There are issues, but it is $60-75.
« Reply #9 on: Fri, 05 May 2017, 11:14:44 »
Also I'd check out r/mechmarket maybe setup a telegram notification for JTK
Offline Encabulator
« Reply #10 on: Sat, 06 May 2017, 19:18:09 »
Jtk sets have 84 key support, right?
Offline Niomosy
« Reply #11 on: Sat, 06 May 2017, 19:28:58 »
Hopefully JTK gets things worked out so we've got more manufacturer options.  Wouldn't mind some more color potential as well.
Offline fishpod
« Reply #12 on: Sat, 08 July 2017, 01:56:19 »
Here's a GB I've been holding, you might want to check it out  ;D ;D
JTK WoB https://geekhack.org/index.php?topic=90108.0
the vendor also offers a 15% for purchasing 2 sets of JTK. Hope this could be helpful  ;) ;)
