Author Topic: [GB] LZ St (COMPLETED)  (Read 119932 times)
Offline futurecrime
  • Get Zooted
Re: [GB] LZ St : Invoice sent
« Reply #100 on: Tue, 16 May 2017, 11:45:06 »
Just out of curiosity caused by the assembly post, are the PCB's for the group buy pre-soldered with resistors, diodes, LED's?
From OP: "Full SMT(pre-soldered Device, Diodes, Resistors)"
Offline Mr_BeastQuake
    • Reddit
« Reply #101 on: Tue, 16 May 2017, 11:54:28 »
To salvage some face, I did read first post! Just not that line :P somehow...
Offline Goon
« Reply #102 on: Tue, 16 May 2017, 11:55:09 »
Paid. waiting on CLS now ST :(
Offline merintil
« Reply #103 on: Tue, 16 May 2017, 12:25:36 »
If my address changes before production ends, can I request to have my order sent to a different address?
I am most likely moving sometime in July/August.
Offline LifeZ
  • LifeZone
« Reply #104 on: Tue, 16 May 2017, 18:49:55 »
CLS, St include pcb.
Diodes, Resistors and RGB Leds(For underglow) is pre soldered.
LZ Limited
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #105 on: Tue, 16 May 2017, 19:31:41 »
that's a really good assembly price.  I'll be using it if I ever join a GB, just not a small form factor user
Same here I usually buy lots of 104 keyed monster's but after a while you get bored always getting the aircraft carrier sized keyboards.
This little baby is for myself to use it helps to concentrate my usage on less keys instead of always being surrounded with tonnes of extra keys to press.
Looking forward to this one mainly because it will be an all purpose built keyboard for me to use, all I have to do is supply the key-caps and plug it into my PC.
Offline LifeZ
  • LifeZone
« Reply #106 on: Wed, 17 May 2017, 01:25:34 »
Sure, no worries!  :D
LZ Limited
Offline ryptide11
« Reply #107 on: Wed, 17 May 2017, 04:08:33 »
My switch plate is blank. Please make it STS. Will it change my invoice price?
Offline LifeZ
  • LifeZone
« Reply #108 on: Wed, 17 May 2017, 04:12:00 »
oh..add sts plate.
no change your invoice price.
LZ Limited
Offline ryptide11
« Reply #109 on: Wed, 17 May 2017, 06:30:34 »
Paid. Thank you.
Offline merintil
« Reply #110 on: Wed, 17 May 2017, 09:23:26 »
Excellent, thank you very much!
Offline NealCaffery
« Reply #111 on: Sun, 21 May 2017, 07:18:24 »
I have paid the invoice, but the chart doesn't update yet. Also, Can I ask for an additional assembly?
Offline Unforgivable
« Reply #112 on: Sun, 28 May 2017, 01:23:39 »
LifeZ,
The Order Check spreadsheet has changed since the last time I saw it..it's very messy and inaccurate now. I didn't order a stainless steel switch plate. :(
Can you please confirm that the below is my order? I already paid for it.
1xRed LZ ST
(With Red aluminum switch plate, PCB included)
1x Brass weight
1xDiffuser
1x Extra PCB
1x Extra Red Aluminum switch plate
Thank you very much!
To everyone else, I would make sure your order is correct. Let's hope LifeZ will fix the spreadsheet. :(
Offline Cocopah
  • Lurker Extraordinaire
« Reply #113 on: Sun, 28 May 2017, 01:52:45 »
LifeZ,
1xRed LZ ST
1x Brass weight
1xDiffuser
1x Extra PCB
That happened to me when I was on mobile, it was acting weird. It's normal on desktop though.
« Reply #114 on: Sun, 28 May 2017, 02:55:16 »
LifeZ,
1xRed LZ ST
1x Brass weight
1xDiffuser
1x Extra PCB
Hey Coco!
You're 100% right! I just checked it on a PC and it was accurate!
So strange how it doesn't show up the same way on mobile.
Please disregard my previous statement, LifeZ! Apologies for any confusion I may have caused, and a big thanks to Coco for a swift answer! :)
Offline Cocopah
« Reply #115 on: Sun, 28 May 2017, 03:23:54 »
 :thumb:
Offline ryptide11
« Reply #116 on: Sun, 28 May 2017, 21:34:12 »
I got an email from paypal on 19 May that my keyboard has shipped.
Is this correct?
Offline LifeZ
  • LifeZone
« Reply #117 on: Sun, 28 May 2017, 23:20:11 »
Is this correct?
A little problem.
It happened because of a small issue in my PayPal account.
I will send PM.
LZ Limited
Offline Elrick
  • Hype Master
« Reply #118 on: Mon, 29 May 2017, 20:37:34 »
Is this correct?
A little problem.
I will send PM.
It was a surprise even for me because normally your cases do not come out this quickly, not even Varmilo works this fast in making keyboards and shipping them that quickly.
Please take your time here, we want PERFECTION with every keyboard made and I know your standards are way higher than most others here on GH Central  8) .
Offline Elrick
  • Hype Master
Re: [GB] LZ St : Production
« Reply #119 on: Fri, 04 August 2017, 19:23:16 »
Dear LZ,
Last time I chimed in it was May and it's now August, so what is happening....... ?
Very eager in finding out the progress of this keyboard and I know the others here in this Group Buy are just as curious.
Offline LifeZ
  • LifeZone
« Reply #120 on: Sun, 06 August 2017, 02:52:07 »
Hello everyone,
This group buy is for a LZ St
IC thread
https://geekhack.org/index.php?topic=88607.0
Detail
Order deadline 2017-05-05  -> 2017-05-12
Order check 2017-05-13 ~ 05-17
Invoice start 2017-05-13
Payment deadline 2017-05-20
Production 12 ~ 16 weeks from 2017-05-25 2017-06-08
Order here
Order check
No letter on the weight plate.
letter on bottom case.
LZ St letter on thr weight plate. (update, 5/10)
Specifications:
Aluminum case
11 degree angled
Aluminum n Stainless steel Switch plate
Brass or STS Weight
Support ISO + ANSI
PCB: L3 LEEKU PCB
Fully Programmable
Full LED backlighting
Case Colors:
Black
SILVER
RED
Switch Plate:
Alu (RED)
STS (Stainless Steel)
Weight Plate:
Brass
Basic kit 1 set of include 1 pcb, 1 Weight plate, 1 Switch plate and TOP&BOT Case
Additional Parts:
PCB Mount Cherry Stabz(1kit) : Cherry genuine / winkey (6.25x-1ea, 2x-3ea)
Extra PCB
Extra Switch plate
Extra Weight plate
Price:(excluding paypal fees and shipping)
Basic kit : $396 (Case, Switch plate, Weight plate, PCB)
Shipping:
Different depending on Order Option
1 set(Box) of weights : about 3.5kg
EMS shipping Price (1set) with Tracking number
Asia : $30
EU, Canada : $55
Usa : $65
The PCB is Designed/Developed by Leeku
The PCB is Programmed with JigOn firmware : http://kbdlab.co.kr/index.php?mid=board_sw&document_srl=2702787
support lay-out
8/6 update.
Case CNC : 70%
alu, sts plate : 100%
pcb : re-testing
LZ Limited
Offline ihalatch
« Reply #121 on: Sun, 06 August 2017, 09:10:02 »
Hi Lz, I can't see the acrylic diffuser in my order. I ordered one. Can you please check my order? Is it too late to order an extra switch plate?
Offline Elrick
  • Hype Master
« Reply #122 on: Sun, 06 August 2017, 19:40:32 »
Hello everyone,
8/6 update.
Case CNC : 70%
pcb : re-testing
Nice one LZ, it's a shame you have to spend so much time on the [GB] LZ CLS   >:D .
I really hope they will appreciate all the effort you've gone through to complete their orders, to your own highest standard  8) .
Really looking forward to your LZ St keyboard.
« Last Edit: Sun, 06 August 2017, 19:43:05 by Elrick »
Offline LifeZ
  • LifeZone
« Reply #123 on: Sun, 06 August 2017, 19:51:26 »
There is no problem with the order. Please check again.
and only extra  alu plate add.
LZ Limited
Offline LifeZ
  • LifeZone
« Reply #124 on: Sun, 06 August 2017, 19:53:03 »
Hello everyone,
8/6 update.
Case CNC : 70%
pcb : re-testing
i see.
Time was delayed due to the large quantity and the problem of anodizing.
I'm trying.
LZ Limited
Offline boo
« Reply #125 on: Sun, 06 August 2017, 20:50:37 »
Hello everyone,
8/6 update.
Case CNC : 70%
pcb : re-testing
i see.
I'm trying.
Thank you LZ!
Offline Captainbuttmonkey
« Reply #126 on: Mon, 07 August 2017, 18:19:21 »
Hi LZ, the order check doesn't seem to have any case marked for me? I'm assuming this was just missed by mistake, I believe I ordered a red one. Many thanks
Offline LifeZ
  • LifeZone
« Reply #127 on: Thu, 17 August 2017, 08:45:18 »
8/17 update.
Case CNC : 90%
pcb : re-testing
brass weight : 20%
176087-0
176089-1
176091-2
176093-3
LZ Limited
Offline smittysteve
  • Tea > Coffee. Clack > Thwock.
« Reply #128 on: Thu, 17 August 2017, 11:30:52 »
8/17 update.
Case CNC : 90%
pcb : re-testing
brass weight : 20%
Thanks for the update, LZ- getting very excited for this board!!
Offline aaron6301
  • Pixel Pusher
« Reply #129 on: Thu, 17 August 2017, 11:50:38 »
8/17 update.
Case CNC : 90%
pcb : re-testing
brass weight : 20%
You and I both, my friend  :thumb:
Offline Elrick
  • Hype Master
« Reply #130 on: Thu, 17 August 2017, 21:24:35 »
8/17 update.
Case CNC : 90%
pcb : re-testing
brass weight : 20%
You are the ONLY person in any Group Buy that says so little, yet provides relevant info on your progress  8) .
LZ is the one and only when it comes to delivering any of his designs on time and on budget.
That is why it's always good to join his GBs without question, when he presents them  :thumb: .
« Last Edit: Thu, 17 August 2017, 21:26:52 by Elrick »
Offline megaforce
« Reply #131 on: Thu, 17 August 2017, 22:40:38 »
8/17 update.
Case CNC : 90%
pcb : re-testing
brass weight : 20%
Love me some Elrick words of wisdom  :thumb: :thumb: :thumb:
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline futurecrime
  • Get Zooted
« Reply #132 on: Fri, 25 August 2017, 17:57:33 »
Is there any chance of getting one of those nice carry cases like I'm seeing in the CLS thread? Like Kin's ones but with the LZ zips.
« Reply #133 on: Fri, 25 August 2017, 17:58:40 »
If we get a nice protective bag with the LZ ST, I'll scream with joy!!!  ;)
« Last Edit: Fri, 25 August 2017, 18:11:57 by Unforgivable »
Offline futurecrime
  • Get Zooted
« Reply #135 on: Sat, 26 August 2017, 02:22:26 »
I pm'd LZ.  No case for St.  :(  But we still get a great keyboard though eh.
Offline Elrick
  • Hype Master
« Reply #136 on: Sat, 26 August 2017, 20:44:48 »
You bet but I think LZ made a mistake for providing the CLS crew with a carrying case and not providing one for this true "portable" styled keyboard.
Even if he offers a nice carry case for this ultra-fine keyboard model, I would still fork out more moolah for it easily.
Supreme keyboards such as the St need their carrying case, just like hand guns, cameras or jewellery  8) .
Offline Elrick
  • Hype Master
« Reply #137 on: Mon, 28 August 2017, 20:02:55 »
Just read what LZ posted in his CLS GB  :o .
That was why he provided an 'extra', which was the keyboard bag to help alleviate anyone's concern for the expanded timeline of his keyboard.
If it helps here, would be glad in just getting this keyboard but I am not stopping you at all if you decide to put in an 'extra' like a keyboard carry bag (being greedy)  8) .
Won't cry if it doesn't happen because he always delivers on his keyboards, especially with his own style and quality.
    • Reddit
« Reply #138 on: Wed, 30 August 2017, 00:43:38 »
me want
Offline LifeZ
  • LifeZone
« Reply #139 on: Thu, 31 August 2017, 19:21:01 »
update. 2017.09.01
PCB final test passed
Start anodizing next week
177274-0
LZ Limited
« Reply #140 on: Thu, 31 August 2017, 21:49:54 »
update. 2017.09.01
Nice!
Is that and LZ-GT I see?
Offline LifeZ
  • LifeZone
« Reply #141 on: Thu, 31 August 2017, 23:16:28 »
update. 2017.09.01
Nice!
Yes. GT!!
LZ Limited
Offline Elrick
  • Hype Master
« Reply #142 on: Fri, 01 September 2017, 00:34:00 »
update. 2017.09.01
NICE, good to see this keyboard still going to spec with no problems  :thumb: .
Offline rasmusx
« Reply #143 on: Fri, 01 September 2017, 04:06:54 »
update. 2017.09.01
Nice! Thanks for the update :)
Offline LDobler
« Reply #144 on: Sun, 17 September 2017, 04:39:00 »
Pretty damn hyped for this puppy! :p
Any updates LZ?
Cheers
Offline LifeZ
  • LifeZone
« Reply #145 on: Sun, 17 September 2017, 07:22:57 »
Extra MX Switch Plate
(Transparent polycarbonate plate  1.5mm)
It is some Burr. It is common.
It is not a defective product.
178482-0
Order
http://naver.me/GQFTjLvd
LZ Limited
Offline aaron6301
  • Pixel Pusher
Re: [GB] LZ St : Production : Extra PC plate Order now
« Reply #147 on: Sun, 17 September 2017, 11:23:53 »
Ordered
Sent from my SAMSUNG-SM-G925A using Tapatalk
Offline Elrick
  • Hype Master
« Reply #148 on: Mon, 18 September 2017, 05:45:14 »
Order
YES the burr exists due to having both sides of the polycarbonate covered in a clear plastic sheet.  The sheet is there to protect the polycarbonate from any scratches BUT it's a pain to use lazers with.
We had some pieces cut many years ago and it left rough edges on any polycarbonate sheet but it leaves silky smooth cuts on Carbon Steel and Ceramics.
Offline mmdango
« Reply #149 on: Tue, 19 September 2017, 14:40:14 »
I would love carrying case to go with this guy :]
