Author Topic: noppoo chock mini  (Read 1840 times)
Offline Djturban
noppoo chock mini
« on: Fri, 05 May 2017, 14:28:14 »
Hey guys, having a strange problem with my choc mini.
Ive had the keyboard for around 2 months and its worked perfectly until today, When I press Capslock nothing happens but when i press Ctrl capslock turns on.
I thought the keys might have remapped somehow but ive tried different keyboards and they all work fine, also tried my choc mini on other PCs and always the same problem.
Anyone know what the problem could be?
Thanks
Offline MrexD
  • aka mrwoodyxd
Re: noppoo chock mini
« Reply #1 on: Fri, 05 May 2017, 15:15:17 »
Thanks
You've just swapped the keys using the Function key.
Trying holding FN + pressing Del to switch them back or FN + one of the other Function keys. One of them will switch them back over.
Pok3r MX CLears
Offline Djturban
« Reply #2 on: Sat, 06 May 2017, 00:52:44 »
Thank you so much! I couldn't figure it out for the life of me!
If anyone else has this problem to change it back you hold down Fn key and press F9, this should swap them back.
Thanks again!
