Author Topic: [IC] Prime Keyboard  (Read 4774 times)
Offline holtenc
[IC] Prime Keyboard
« on: Sun, 07 May 2017, 20:35:46 »
Hello everyone. Please take the time to fill out a very quick survey on the keyboard. And I apologize in advance that it requires a google sign-in. I would rather have quality over quantity.  :p
Survey Link: https://goo.gl/forms/gT6gxz9vS8eJYhq42
Offline kmba
  • Formerly tameone
Re: [IC] Prime Keyboard
« Reply #1 on: Mon, 08 May 2017, 12:54:43 »
Could you get the PCB to fit a commercially available case like the tada68 alu?
keyboards.
Offline holtenc
« Reply #2 on: Mon, 08 May 2017, 15:46:25 »
Unfortunately that won't be possible  :(
The one that is pictured here is actually in a TADA68 case, but it's heavily modified to make it work. The mount holes that are on a stock TADA68 case would never line up right. Additionally, this keyboard is going to be built by mounting the switch plate to the case, as opposed to mounting the PCB to the case.
