Author Topic: Custom programmable 4-switch PCB?!  (Read 2346 times)
Offline monojira
« on: Wed, 10 May 2017, 19:00:12 »
Hello,
I'm looking to build a tiny device with 4 switches (can be 6 or 8 or even a fully programmable numpad if nothing else works) with USB connectivity.
The main issue here is that it needs to be programmable and affordable. Does anyone know where I could get a PCB like that?
Edit: Also, would any numpad PBT be customizeable?
« Last Edit: Wed, 10 May 2017, 19:10:12 by monojira »
Offline TalkingTree
    • My projects
Re: Custom programmable 4-switch PCB?!
« Reply #1 on: Thu, 11 May 2017, 04:22:48 »
There's a 3 switches business card which comes even already assembled on Techkeys.
As for numpads, you can buy ready made products such as the winkeyless.kr B.pad X2, GON's GONpad (although be aware there's some controversy regarding GON delivery time, so make you sure you browse the forums and make up your mind), or you can use a breakout board and make your own, as I did.
Offline Phenix
« Reply #2 on: Fri, 12 May 2017, 13:51:49 »
i throw in the lets split as an matrix macro pwd..
Winter is coming.
Offline mrbishop
  • Evil Genius
    • Bishop Computer Design web
« Reply #3 on: Mon, 15 May 2017, 11:09:36 »
thats exactly what i did...
if you want a lets split PCB www.switchtop.com is in re-supply mode right now. more should be in in afew weeks.
Projects
Build to give back, 40% | Alps/Matias Removal ToolUltraHack 67% Hackdura  | ErgoDox case
