Author Topic: Measurements for HHKB blockers (7u bottom row) in 60% case?  (Read 2750 times)
Offline E3E
Hey! I'm trying to work out the measurements for the blockers in a Viper-style case for the blockers for something a friend and I are designing. Does anyone have any info on the measurements for these blockers?
Offline Delirious
Re: Measurements for HHKB blockers (7u bottom row) in 60% case?
« Reply #1 on: Wed, 10 May 2017, 19:51:24 »
I used Mod's resource to draw my plate and it was dead on. Look for the keylayouts.dwg
Using the same one I got this
Offline E3E
« Reply #2 on: Wed, 10 May 2017, 21:41:28 »
Thanks man! I'll check it out!
Offline xondat
  • i'm not a star
« Reply #3 on: Wed, 10 May 2017, 22:10:39 »
You should treat it the same as doing the usual outer border. From the edge of the switch cutout, you go 3mm out, and that's where the the blocker begins.
For ease sake, it's 28.5750mm.
You can also work out that by doing 19.05 x 1.5 (overall switch space x switch unit size).
