Author Topic: HHKB Pro2: Menu key  (Read 3542 times)
Offline konz
HHKB Pro2: Menu key
« on: Mon, 22 February 2010, 04:56:41 »
The left and right OS (or Windows) keys on the HHKB Pro2 are left and right OS keys, not a left OS key and a Menu key.
This explains why the HHKB Pro2 has the option of mapping the left OS key to Fn thus avoiding "claw finger" combinations for arrow keys, etc. -- the amount of keyboards having left and right OS keys is minuscle (Fujitsu Siemens KBPC E is an example) and no software I am aware of depends on this.
However, it leaves us without a convenient Menu key.
Is there a better way of generating Menu key than emulating it using Shift-F10 (standard at least under Windows)?  Are programs known that support the Menu key, but not Shift-F10?
Offline ch_123
HHKB Pro2: Menu key
« Reply #1 on: Mon, 22 February 2010, 08:15:54 »
Some sort of software mapping... AHK or Linux's inbuilt tools.
I can't imagine why you'd need the Useless Key though...
Offline test157
HHKB Pro2: Menu key
« Reply #2 on: Mon, 22 February 2010, 08:30:48 »
yeah, and if really Shift F10 works almost everywhere in linux or in windows, in eclipse at least
« Last Edit: Mon, 22 February 2010, 08:32:50 by test157 »
Offline bigpook
HHKB Pro2: Menu key
« Reply #3 on: Mon, 22 February 2010, 09:43:52 »
shift + F10 seems to work for me in Ubuntu on a Dell laptop.
Offline konz
HHKB Pro2: Menu key
« Reply #4 on: Tue, 23 February 2010, 01:17:39 »
Quote from: ch_123;159946
I try not to use a mouse.  I don't like leaving the home row.
This brings up a second topic: anyone know how to generate keypad keys on a HHKB Pro2 so that Windows MouseKeys works?
