Author Topic: Ducky Premier - FN key acting like Menu key  (Read 1377 times)
Offline garbanzo
« on: Fri, 19 May 2017, 19:11:43 »
Preface: I'm having trouble using my Ducky Premier with some games - I can't walk forward, I just jitter around. Some games work fine, while others don't. I narrowed it down to a keyboard issue, and after some research, I think it has something to do with my key repeat settings.
But alas! I can't change the key repeat settings on my Ducky, because for some odd reason, my FN key is acting like a Menu key. This means no backlight or other nice features either.
I emailed Ducky support, but after tellign me to do a factory-reset on my keyboard (which didn't help), they stopped responding to my emails.
Any thoughts? Thanks!
Re: Ducky Premier - FN key acting like Menu key
« Reply #1 on: Fri, 19 May 2017, 19:45:51 »
Do you have the manual? Sounds like your dip switch settings need checked.
