Author Topic: Building a custom Filco 104  (Read 1838 times)
Offline talthalra
« on: Mon, 22 May 2017, 10:46:53 »
Do a PCB and plate exist anywhere in the world that would fit into this nice aluminum Filco case I found. Is my only option to buy a used Filco for the PCB and plate? Please someone tell me no.
Offline leech
  • …always on the lookout for higher quality…
Re: Building a custom Filco 104
« Reply #1 on: Mon, 22 May 2017, 16:25:52 »
Do you have photo of 104 FILCO aluminum case?
Can it be purchased from where?
Offline talthalra
Offline leech
« Reply #3 on: Tue, 23 May 2017, 11:51:04 »
https://world.taobao.com/item/542910702075.htm
Looks great, thanks! The price seems right too.
I had considered swapping my case from original white plastic to such custom aluminum.
 :cool:
Offline TerryMathews
« Reply #4 on: Wed, 24 May 2017, 11:13:28 »
imgur.com/a/juHQN
I couldn't find a 104 PCB and plate that fit the Filco case, so I desoldered a Majestouch 2 and added a Tiger Lily controller for good measure.
