Author Topic: FC980M - Add LEDs for shine through caps?  (Read 2874 times)
Offline Ef_Oh_Ex
« on: Mon, 29 May 2017, 20:14:05 »
I have an FC980M. What I'd like to do is add an LED to each shine through cap on the board. Well there isn't an LED socket for the shine through key caps on the PCB.
Sooo, does anyone know if it would be possible to just wire one in? I could solder onto the factory LED light stems above the number pad?
The problem I see happening is there will not be enough power sent to the LED to power two LEDs from one socket.
Does anyone have experience with this?
Offline Ef_Oh_Ex
Re: FC980M - Add LEDs for shine through caps?
« Reply #1 on: Mon, 29 May 2017, 21:52:19 »
I just tested this concept on a Varmillo VA12M and it worked... one socket powered 2 LEDs.
I can't see why this wouldn't work on the FC980M.
Offline dwarflemur
« Reply #2 on: Tue, 30 May 2017, 00:18:11 »
It should work, but depending on how they set the current they might be dim.
Camp C225 | Norbatouch | ALF X2 + X3 | Orange TKL | CA66 | Leaf 60 | a bunch of others
Offline Ef_Oh_Ex
« Reply #3 on: Wed, 14 June 2017, 16:40:59 »
Come to find out the FC980M pcb already has holes for LEDS for the numlock and caps lock switches. I simply soldered an LED into these provided holes and bingo, it works!
170914-0
