Author Topic: My IBM 3278 / IBM 6580 Beam Spring Keyboards.  (Read 8902 times)
Offline mrduul
« on: Tue, 30 May 2017, 03:16:05 »
Here it is, My beauty. An amazing keyboa- oh..
Wait wait...
shhhhh she is sleeping....   ;D
« Last Edit: Fri, 11 August 2017, 05:18:42 by mrduul »
Offline mrduul
My IBM 3278 / IBM 6580 Beam Spring Keyboard.
« Reply #1 on: Tue, 30 May 2017, 10:22:07 »
Well she's awake this morning and will need a cleaning but here are some pictures.  :D
Enjoy, will take more photos when I start cleaning inside the board.  8-)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
Desk Setup
I took pictures of the full IBM 3278 Manual and compiled a PDF file.
PDF is uncompressed, 200MB.
Download IBM 3278 Manual by MrDuul: http://www.mediafire.com/file/uy22uys64lcgozk/IBM-3278-Manual.pdf
I didn't crop the photos because it looked not good.
Won't be scanning because I really don't want to risk pressing on the manual and potentially damaging it.
(The link keeps going down sometimes, not sure why)
« Last Edit: Sat, 03 June 2017, 08:16:30 by mrduul »
Offline thad
Re: My IBM 3278 Beam Spring Keyboard.
« Reply #2 on: Thu, 01 June 2017, 09:31:31 »
Nice. I just want to type on one once to see what it's like.
Sent from my SM-G950U using Tapatalk
Offline K3lp_Boy
« Reply #3 on: Thu, 01 June 2017, 09:58:55 »
I'm assuming there's no way to connect these beauties to modern computers?
They still make great display pieces, though.
Ducky One w/ Cherry MX Blues, Tai-Hao Lavender doubleshots
Planck on the way!
Really into lofi hip hop now.
Offline Pretendo
« Reply #4 on: Thu, 01 June 2017, 10:13:48 »
You can, but it's by no means a simple plug and play.  I'm oversimplifying, but you essentially have to build your own controller.  It's been done by some of the more die-hard beam-spring aficionados out there.
IBM Model F-122 6110347 -- September 13th, 1984
IBM Model M 1391404 -- April 14th, 1988
Rosewill RK-9000
Offline mrduul
« Reply #5 on: Thu, 01 June 2017, 13:50:29 »
All beamsprings can be modified to be used over USB using a xwhatsit beamspring controller PCB. https://geekhack.org/index.php?topic=58138.0
My displaywriter is USB modified.
Except the 3277 which is only PS/2 and then you can just use a PS/2 to USB adapter.
Here is a video of beamspring connected via usb. VERY CLICKY with solenoid turned on, loudest mechanical switch ever like a typewriter.
At 0:40 solenoid is turned on.
« Last Edit: Thu, 01 June 2017, 14:04:01 by mrduul »
« Reply #6 on: Thu, 01 June 2017, 17:15:17 »
Reminds me of this when you turn the solenoid on.
Offline mrduul
« Reply #7 on: Thu, 01 June 2017, 18:22:27 »
Yeah man that is gold.  ;D
Offline alienman82
« Reply #8 on: Thu, 01 June 2017, 18:46:48 »
removed.
« Last Edit: Thu, 01 March 2018, 12:43:14 by alienman82 »
Offline mrduul
« Reply #9 on: Thu, 01 June 2017, 19:20:23 »
You can do the dental floss trick to get less of the "ping" on Model F.
https://deskthority.net/wiki/Dental_floss_mod
« Last Edit: Thu, 01 June 2017, 19:39:12 by mrduul »
Offline invariance
  • ...here with all the other boson's
« Reply #10 on: Fri, 02 June 2017, 03:19:55 »
Wish I had one though.
« Last Edit: Fri, 02 June 2017, 03:22:43 by invariance »
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
Offline mrduul
« Reply #11 on: Fri, 02 June 2017, 04:00:38 »
Well you got your model M mah brah  :p
Offline pr0ximity
« Reply #12 on: Fri, 02 June 2017, 05:26:37 »
Not in the least bit true. Find an xwhatsit, unplug the old controller, plug the xwhatsit in it's place. Literally no soldering involved, the controller is attached via a socket.
USB, fully programmable, NKRO. It's pretty damn great, tbh.
Offline mrduul
Re: My IBM 3278 / IBM 6580 Beam Spring Keyboards.
« Reply #13 on: Fri, 02 June 2017, 06:40:36 »
Exactly.
See here:
Offline Pretendo
« Reply #14 on: Fri, 02 June 2017, 07:30:58 »
Should have known that.  I knew you couldn't do it with a Soarer's Converter, but I'd seen demonstrations of them working on Youtube.
I'd love to try a beam spring.  As it stands, I just upgraded from an early 1391401 Model M to a 122 Model F last week, so I couldn't justify an expensive keyboard purchase any time soon.  The F still needs a full restoration (a couple of the keys are a bit gummy -- likely a rotting foam issue) so I have plenty to keep me busy over the next year or so.
Rosewill RK-9000
