Author Topic: phantom pcb with holtite sockets compatability  (Read 1774 times)
Offline PocoLoco
« on: Wed, 31 May 2017, 14:21:13 »
As the topic says i have a phantom pcb  and i would like to put holtite sockets to make it easier to remove switches does anyone know if they are compatible ?
Offline alienman82
Re: phantom pcb with holtite sockets compatability
« Reply #1 on: Thu, 01 June 2017, 19:09:17 »
removed.
« Last Edit: Thu, 01 March 2018, 12:43:09 by alienman82 »
« Reply #2 on: Thu, 01 June 2017, 19:40:10 »
It is a question of whether the holes are wide enough for the holtite sockets.
That would depend on the size of the hole that was drilled, the thickness of the plating and the particular holtite socket that you are using (there are several sizes).
Someone will just have to try it out. Myself, I am typing on a Phantom but I have no sockets.
« Last Edit: Thu, 01 June 2017, 19:43:56 by Findecanor »
