Author Topic: [IC] Anodized aluminum case separable cable for Filco TKL [GB launched]  (Read 19029 times)
Offline sennin32
    • Doyu Studio
Re: [IC] Anodized aluminum case separable cable for Filco TKL [GB launched]
« Reply #50 on: Tue, 04 July 2017, 16:43:00 »
Can you show us a sample of the "deep blue" color?
I'm guessing it is royal blue, but "deep blue" in the US could also mean navy blue.
Still unsure on this one based on the photos. I'd like to see what the bottom plate looks like in more detail since it's described as a thin piece of metal, some colors and maybe some anodizing samples if possible.
I'll take some more pics after back to Taiwan.
Include bottom plate.
For the color, I'lll ask some sample plate :)
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
http://imgur.com/8mTw3NG.jpg
USB hole has modified.
And from the result.
This case will be made with Gray, Black and Deep blue :)
Will the angle be the exact same as the stock case without the feet up, and if it is, will there be holes to add feet to raise the angle?
Also, can we see some pics of the inside of the case (how the plate sits in it)?
« Last Edit: Wed, 05 July 2017, 00:34:50 by CommonCurt »
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline duynguyenle
  • Personal text? What personal text???
I too would like to see a picture of how the plate is mounted before committing to buy, I have a Quickfire Rapid which is manufactured by the same OEM as filco, but I believe there are slight differences in the dimensions that they use for the plate and how it's retained in the case.
Please update us with pictures when you are able to, sennin!
 :thumb:
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #53 on: Sat, 08 July 2017, 18:09:47 »
What about those inside pictures?
We have about 7 days left to decide if we want to order.
WTB/WTS/WTT ---->
