Author Topic: [GB] BananaSplit60 Orders Shipping Out 7/27! Shipping 100% Complete  (Read 171852 times)
Offline evangs
  • TheVan
Re: [GB] BananaSplit60 Orders Shipping Out 7/27! Shipping 100% Complete
« Reply #400 on: Tue, 24 October 2017, 22:29:50 »
In for another round if it happens, been awhile since I have been on geekhack, shame I missed this. Would be a nice addition to my collection and rotation.
2nd round happening end of this month :D. It'll be even bigger and better  :thumb:
Any news about this??? the end is coming.....
Launched on the 31st we will be posting some info soon
Offline Sputnik
« Reply #401 on: Wed, 25 October 2017, 13:44:20 »
Great, I wait.............
Offline ojrask
  • juuh elikkäs
« Reply #402 on: Fri, 27 October 2017, 05:52:17 »
Does the R1 PCB support per-key RGB and if not is this planned for R2? Did not see any notes about this anywhere. Somewhere I read that R2 has some support for RGB underlighting though.
Current:
Coming up:
IC/GB:
Offline ChitownM2
« Reply #403 on: Fri, 27 October 2017, 13:08:53 »
R1 had no rgb or underglow.
Per key rgb would be a pretty substantial change and I'm betting that won't be incorporated into a R2 that is happening this quickly.  Not saying I wouldn't like it, but from what little I know I'm pretty sure it would require a ground up redesign of the pcb.
Offline Arhipio
  • TheBananaMan
« Reply #404 on: Fri, 27 October 2017, 16:03:10 »
We are not supporting either.
Offline ojrask
  • juuh elikkäs
« Reply #405 on: Fri, 27 October 2017, 17:12:59 »
Thanks. A coworker is looking for a split space keyboard and he really likes his LEDs. Will continue the search. I'll have to see if R2 changes warrant getting another BS60 for myself though. ;)
Current:
Coming up:
IC/GB:
Offline Zobeid Zuma
« Reply #406 on: Fri, 27 October 2017, 19:14:16 »
KBDfans DZ 60 does come with RGB underglow installed, and it supports single-color LEDs per key.  However, the LEDs are oriented to the bottom/front of each key instead of the top.  It's backward from most boards and backlit keycap sets, although they do have this set --> https://kbdfans.myshopify.com/collections/keycaps/products/front-side-printed-backlit-keycaps-104-87-iso-ansi-layout-translucidus-backlit-keycaps-for-corsair-strafe-k65-k70-logitech-g710
Offline pvd
« Reply #407 on: Fri, 27 October 2017, 20:32:37 »
I wanted to change up the layout on my banana split so I tried to flash the keyboard a second time, but I'm stuck on this step in the online guide:
"In Device Manager find the ATmega32u4 device and right click on it."
I don't see any ATmega32u4 device under the device manager.
Offline kitchenace13
« Reply #408 on: Fri, 27 October 2017, 21:26:41 »
Are you doing it via PC? Just asking cause thats what I do... I've flashed mine a few times and never ever even try to find it in device manager.  I just download a new HEX file from the website, start up that application Atmel Flip Bootloader, use the reset button on the keyboard bottom, use connect via USB in the Bootloader, load the hex file in the Bootloader, then click Run, then Start Application.
This website (https://thevankeyboards.com/pages/programming-guide) really starting at Step 2 - Flash Compiled Firmware Onto Keyboard
Not sure if that helps.
Offline pvd
« Reply #409 on: Fri, 27 October 2017, 22:01:46 »
Thanks for trying to help. If I just press the button on the bottom of the board and then use the flip bootloader, I get this error.
https://imgur.com/c0fZCSr
Any ideas? I did successfully flash it a few months ago, so I'm not sure what I'm doing wrong now.
Offline Zobeid Zuma
« Reply #410 on: Sat, 28 October 2017, 06:27:54 »
Are you using the same computer that you did before?  That's the error I got when Windows didn't have the Atmel device driver installed.  It gave me fits until I figured that out.  Whole ordeal documented here --> https://geekhack.org/index.php?topic=92072.msg2505956
Offline pvd
« Reply #411 on: Sat, 28 October 2017, 09:47:08 »
I am indeed using the same keyboard as before. I read through your thread and I think maybe my problem is appearing here: https://imgur.com/a/LDj1f
In my device manager, after pushing the reset button, the list of devices blinks, but there is still no ATm32U4DFU or any LibUSB-Win32 category on the list.
« Reply #412 on: Sat, 28 October 2017, 21:48:01 »
I get that error sometimes, I think I had to hold down the reset button longer?  My split is at work so I can try it again on Monday and let you know.
Offline Arhipio
  • TheBananaMan
« Reply #413 on: Tue, 31 October 2017, 13:08:58 »
Round 2 of the BananaSplit60 is live along with XDA 8Bit, Retro60 and white powdercoated MiniVan and Roadkit. Purchase now at https://thevankeyboards.com/
« Reply #414 on: Tue, 31 October 2017, 14:23:16 »
Hey man okay sorry it took me so long to reply.  So here is my step by step which I just used to flash my BSplit with a new programming (reprogrammed two blank keys to pgup & pgdn).  Basically, I don't look at, don't touch, and don't even open Device Manager.  I don't even know where in the instructions it says to go looking for your keyboard there.  See below for my steps and hopefully they help.
  • Make sure your BSplit keyboard is plugged in the whole time (and the only keyboard you have plugged in?)
  • Go to http://minivan.config.thevankeyboards.com
  • Adjust the configuration to what you want in the TMK Configurator
  • Click "Make Hex"
  • Get the resulting downloaded file (i.e., bananasplit_2017-10-31-18-54-26.hex) and keep it somewhere you can find it easily
  • Get a paperclip and depress the SW_RESET key on the underside of the BSplit keyboard for about 10 seconds.  Just clicking it or holding it for like 1 second doesn't work, I just hold it down for a decent amount of time I think this is where your problem is?
  • Start Flip 3.4.7 application with the ATMEL Icon
  • Click on the USB cable icon which is "Select a Communication Medium"
  • Select USB and click Open
  • All of the text and circles should turn active and become a darker grey or black instead of being lightly  grey'ed out like they were before.  Also the bottom right corner of the window will now say "USB On"
  • Click on Load Hex and select the newest Hex file you just downloaded (it should have the current date/time stamp)
  • In the bottom left it should now say "Hex File Parsed"
  • Verify all of the Operations Flow options on the left are checked (Erase, Blank Check, Program, Verify)
  • Click Run
  • The bottom left of the window should say "Verify Passed" and all the Operations Flow circles should now turn green
  • Make sure the "Reset" check box is checked in the bottom right
  • Click "Start Application" and the bottom right corner of the application will say "Communication OFF"
Edit: If you're still running into problems where you can't open the USB connection, can you click on the Chip icon in the ATMEL application or go to Device --> Select and make sure its pointed towards "ATmega32U4"?  Then try opening the USB connection?
« Last Edit: Tue, 31 October 2017, 14:31:19 by kitchenace13 »
Offline cshort97
« Reply #415 on: Wed, 01 November 2017, 13:48:41 »
After following all of these tips, I still get the same error (on two separate PCs, each using two different USB cables). The device shows up in Device Manager as Unknown USB Device (Code 43) and Flip still shows "Could Not Open USB Device".
I hate to jump to this conclusion, but did I somehow mess up the PCB while soldering? Could it be a bad PCB? :(
« Last Edit: Wed, 01 November 2017, 13:50:17 by cshort97 »
Offline Arhipio
  • TheBananaMan
« Reply #416 on: Wed, 01 November 2017, 13:57:03 »
Go ahead and email thevankeyboards@gmail.com we can see about getting you a replacement :)
Sent from my Nexus 5X using Tapatalk
Offline dodgeyhack
« Reply #417 on: Sat, 04 November 2017, 08:03:39 »
181551-0
Need to make some modifications to the case to avoid damaging the SMDs, but the arrival of both Yuri and round two prompted me to finally build this bad boy. Love it!  ;D
Side note, this one is eventually destined for one of the kbdfans grey aluminium cases that ran recently.
Offline Arhipio
  • TheBananaMan
« Reply #418 on: Sat, 04 November 2017, 12:17:31 »
That's beautiful, well done :D
Offline tristinDLC
« Reply #419 on: Sun, 05 November 2017, 03:01:05 »
Damn, there is an R2 with some upgrades before I even got a chance to build my R1.... God dammit. Now I don't know what to do.
Offline sithlord
« Reply #420 on: Mon, 06 November 2017, 23:14:23 »
Any chance for PCB only in R2?
Offline Arhipio
  • TheBananaMan
« Reply #421 on: Tue, 07 November 2017, 14:44:46 »
Keeping it simple with only two options. Sorry we won't be changing it mid groupbuy.
Offline alex1577
« Reply #422 on: Wed, 08 November 2017, 18:36:41 »
Is this layout supported by the pcb and plate? I can't really tell. The layout has a 1.75 shift, and the bottom row is 1.5,1.5,6.25,1.25, 3 x1. Their is also a .75 offset on the bottom row Thanks181838-0
« Last Edit: Wed, 08 November 2017, 20:59:10 by alex1577 »
Offline Arhipio
  • TheBananaMan
« Reply #423 on: Thu, 09 November 2017, 13:19:05 »
Is this layout supported by the pcb and plate? I can't really tell. The layout has a 1.75 shift, and the bottom row is 1.5,1.5,6.25,1.25, 3 x1. Their is also a .75 offset on the bottom row Thanks (Attachment Link)
No here are the supported layouts:
You can do a 7u with 1.5/1/1.5 on both sides or have 4 1u's on the other side.
Offline ashwinv11
  • give me foog
« Reply #424 on: Wed, 13 December 2017, 21:32:17 »
I'm a dummy and bought the wrong kind of plate from Sentraq that doesn't support the layout I want :( are there any plate extras? Or does anyone recommend a place to buy a plate for the universal layout?
Offline Arhipio
  • TheBananaMan
« Reply #425 on: Thu, 14 December 2017, 11:54:39 »
We'll probably have some extras i can see about sending you a prototype extra if you want?
Offline AuthenticDanger
« Reply #426 on: Fri, 15 December 2017, 12:02:38 »
Anyone put LED Holtites into their Banana Split build? I got some but they don't fit into the PCB... my switch Holtites do, just not the LED ones.
I got part number 6-1437514-7 / 8134-HC-5P3 as that was the size I found on various posts.
F Keys belong on the left.
Offline ashwinv11
  • give me foog
« Reply #427 on: Fri, 15 December 2017, 16:32:10 »
Thanks so much for the offer! I reached out to Evan and luckily he said he had a few extra plates so I'll be coordinating with him :)
Offline chuckdee
« Reply #428 on: Sat, 16 December 2017, 15:45:42 »
Figured it out.  Thanks!
« Last Edit: Sat, 16 December 2017, 20:47:10 by chuckdee »
Offline dr-slump
« Reply #429 on: Sun, 17 December 2017, 11:43:53 »
I've holtited the whole board (switches & LEDs).
The LED ones were ordered from here https://mehkee.com/collections/leds-and-sockets/products/holtite-sockets-for-leds-gold?variant=37156780815 (no model number but the specs are available)
and the switch holtites from ZealPC.
They fit perfectly (installed with a soldering iron)
Waiting for GMK Miami Dolch ISO . . .
Looking for: Titainium Spacebar 6.25
Offline chuckdee
« Reply #430 on: Thu, 21 December 2017, 10:54:21 »
Any R2 Banana Split going to be available as extras?
Offline SantiGo
« Reply #431 on: Sun, 21 January 2018, 06:01:35 »
Hello there is information when orders are ready R2 ... ???
Offline Arhipio
  • TheBananaMan
« Reply #432 on: Tue, 23 January 2018, 13:23:40 »
Hopefully by the end of the month. We are waiting on the plates to be shipped to us.
Offline arhetue
« Reply #433 on: Mon, 12 February 2018, 12:53:00 »
Just got my shipping notification! Looking forward to seeing the board - anyone know if this will fit into an FC660 housing?
Offline ojrask
  • juuh elikkäs
« Reply #434 on: Thu, 22 February 2018, 07:10:06 »
I'm having some trouble with my BananaSplit (R1). When I lock my PC (Ubuntu) and return after a while I can type ONE letter and then the keyboard just dies and I can't type anything anymore. I need to plug it in again to make it work normally. After pluggin in again nothing strange happens, only when I step away from it for a while the issue appears.
Could this be related to some QMK bootmagic stuff? I had a somewhat similar issue with my UK78 when I first programmed it with QMK. Here is my QMK setup for BS60: https://github.com/qmk/qmk_firmware/tree/master/keyboards/bananasplit/keymaps/rask
Current:
Coming up:
IC/GB:
« Reply #435 on: Thu, 22 February 2018, 11:12:01 »
for sure will not
Offline ReverbSlush
  • 16/52 RNG score
« Reply #436 on: Tue, 06 March 2018, 12:55:28 »
enjoying my BS
Offline chuckdee
« Reply #437 on: Tue, 06 March 2018, 14:47:13 »
Nice... canvas looks good on there!  Has me thinking of using Godspeed XDA!
Offline Arhipio
  • TheBananaMan
« Reply #438 on: Tue, 06 March 2018, 17:26:43 »
I just got XDA Godspeed I was gonna slap it on a BananaSplit. I can maybe make a post this weekend with some pics :D
Offline chuckdee
« Reply #439 on: Tue, 06 March 2018, 17:32:54 »
Still waiting on the extras to go on sale... so I can't actually do it yet. :)
Offline Arhipio
  • TheBananaMan
« Reply #440 on: Tue, 06 March 2018, 18:54:08 »
I'm pretty sure I stated it somewhere but we have like 10 boards. We aren't going to have extras. Our sales weren't high enough to stock up on inventory :/ if we had 200 we could have easily bought 50. We only hit 100, meaning we only bought 20 or so extras which have been and are being used as replacements for people.
Offline chuckdee
« Reply #441 on: Tue, 06 March 2018, 19:29:50 »
OK, cool to know.  I'd read somewhere that the extras were going to be posted after the buy, but if there are no extras, there are no extras.  Thanks for the clarification.
Offline vim_commando
    • LaserCTRL
« Reply #442 on: Mon, 19 March 2018, 21:01:43 »
Oh noes! Don't tell me I'm going to have to do a non-banana split PCB for my GMK Laser build!
Where there's a will, there's a way...
Offline Arhipio
  • TheBananaMan
« Reply #443 on: Mon, 19 March 2018, 21:35:12 »
Sorry for the miscommunication. I talked to evan we will have extras up on the site but there will be a very tiny amount. Keep your eyes peeled on the site  :thumb:
Offline chuckdee
« Reply #444 on: Mon, 19 March 2018, 22:08:26 »
Thanks for letting us know!  I'll be on the lookout!  :thumb:
Offline sithlord
« Reply #445 on: Wed, 21 March 2018, 23:51:07 »
I got a 404 not found when searching...don't tell me I already missed it.
I want another PCB to build one more...
Offline Arhipio
  • TheBananaMan
« Reply #446 on: Thu, 22 March 2018, 11:33:00 »
No not yet, we're still waiting on the warehouse to ship us the extras :)
Offline chuckdee
« Reply #447 on: Thu, 22 March 2018, 12:09:01 »
Pretty sure he'll announce it on the mailing list when he puts it up.
Offline sithlord
« Reply #448 on: Tue, 27 March 2018, 20:41:50 »
I was afraid I had already missed it. :))
Offline Arhipio
  • TheBananaMan
« Reply #449 on: Sun, 08 April 2018, 15:48:31 »
Hey everyone we launched our new profile called HuB inspired by cherry and spherical keycaps. Go check out our GB and Kickstarter threads if you are interested in this project.
https://www.kickstarter.com/projects/thevankeyboards/hub-mechanical-keyboard-key-caps?ref=3nyt34
https://geekhack.org/index.php?topic=94974.0
