Author Topic: Re: [IC] XDA Melon ( IN PRODUCTION & More information available on GB borad )  (Read 120561 times)
Offline hormbre
  • I am not played by keycaps = =!
All right, let's think about Ergo kit. Here are some kinds of design for Ergo:
1. Alpha + Mod
2. Mod
3. Mod ( blank )
Which one would you like ?
« Last Edit: Tue, 18 July 2017, 17:09:32 by hormbre »
Offline ALKAHEST
Love seeing how this set is refined step by step. Very excited to see something in XDA profile again.
"Doesn't look like anything to me."
Offline Bob
  • Kaleidographer
Very excited by the new additions. Inverse dye-sub makes this set really special! I'm also loving the new coloured melon slice novelty cap you designed, and especially loving the planck kit given that it has fuller sized ortholinear sets in mind. The only suggestion I can really make at this point would be to rename the "planck kit" to "ortho kit" for accuracy [edit: and maybe add an alternate colorway kit for the F row to have a complete green stripe?]. Nice work all round! :thumb:
« Last Edit: Mon, 17 July 2017, 23:10:42 by Bob »
TG3 BL82, Cherry MX clears
Access IS 15x8 matrix layout, Cherry MX blacks
Offline colgateam
So wait...with the inverse dye sub, they will basically dye the whole cap a lighter colour first, then mask the lettering to dye a second time in the darker colour?
Sounds like a huge hassle lol
Offline Bob
  • Kaleidographer
That's why it doesn't come up very often, but as the community demands more and more of manufacturers they figure out a way to make it work. Until recently one of the biggest advantages double-shot had over dye-subbed (apart from legend clarity) was the whole "you can't put lighter legends on darker caps" issue. Now it's just a question of quality control and keeping it cost effective. I'm keen to see the samples... and find out the cost  ;)
Offline hormbre
----Have already changed the name to "Ortho/Planck kit", thanks !
Offline Bob
  • Kaleidographer
Too fast!  ;D
Offline heliar_mk
1. Alpha + Mod
2. Mod
3. Mod ( blank )
Love No.2.
Offline Scarhoof
XDA caps can be rearranged anywhere because they are flat, right? If that's the case then you don't need a separate Colemak set, you would just need A homing row for the Dvorak/Colemak? Could that be rolled in with another set or base as you would only need four keys? HUNT.
Offline Hazzula
Yeah theyre all flat. And I that sounds like it would be cool to have d/c homing keys too. I know the xda milestone has those so it can be done for sure
Sent from my SM-N9005 using Tapatalk
Offline Bob
  • Kaleidographer
I was just taking another look at the ortho/planck kit and realised that since the base kit includes all the TKL mods, the following keys are doubled up on for ortho users: up, down, left, right, page up, page down. You could probably either remove those from the ortho/planck kit or replace them with blanks.
At the moment I'm planning on buying the base kit, two of the 1U space keys kits, two ortho kits, and still undecided on the novelty kit. I'm really hoping those samples come through looking good  ;)
Offline kmba
  • Formerly tameone
Base, tsangan, novelties, 7a space kit for me. With the addition of the spacebar kits this provides great coverage for is splitters. Should work nicely with my banana split.
keyboards.
Offline hormbre
Updated on Jul 21th : 1. Homing keys has been added for Colemak/Dvorak layout . 2.ErgoDox kit added .     Thank you !
« Last Edit: Fri, 21 July 2017, 03:20:42 by hormbre »
Offline heliar_mk
Hope it could be drop soon :D
Offline Muiju
Very interested! Will buy once GB starts
its yo girl
LZ CLSm | mech27v2 | DC60 | E7-V1 |  x1.1
lubed filmed Tealios <3
Offline Sylvester
The design is simple,bt look nice。
Offline hormbre
« Last Edit: Mon, 21 August 2017, 02:44:43 by hormbre »
Offline hormbre
Re: [IC] XDA Melon ( Gamer set added for MOBA/FPS, updated on Aug 13th )
« Reply #117 on: Sat, 12 August 2017, 18:02:34 »
Updated on Aug 13th : 1. Gamer set has been added for MOBA/FPS games.     Thank you !
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #118 on: Fri, 18 August 2017, 15:17:25 »
I voted on Massdrop but i'm not familiar with this type of poll system. Will ISO be available even if it doesn't get much votes or not?
Offline hormbre
« Reply #119 on: Sat, 19 August 2017, 19:27:36 »
Hi ! Thanks for your surpport!
1.This vote is used for Opening Group Buy on MassDrop.
2.There is no relationship between the votes of each kit and availability from Group Buy, it will be determined by author and MassDrop together AFAIK.
Offline hormbre
« Reply #120 on: Mon, 28 August 2017, 22:43:50 »
Updated on Aug 29th : 1. Numpad Kit has been extended to match 21-key Mechanical Numpad. Thanks to tectonicplate@MassDrop ! 2. Samples won't be available this month due to the delay of manufacturer.      Thank you !
« Last Edit: Wed, 30 August 2017, 23:15:48 by hormbre »
Offline JSaintS
    • JSaintS
Re: [IC] XDA Melon ( Numpad extended to match 21-key Numpad, updated on Aug 29th )
« Reply #121 on: Wed, 13 September 2017, 16:22:47 »
Are those spacebar (7E spacebar kit) 6u? Cause if so, then I need it even more than I thought I needed this set!
Offline hormbre
« Reply #122 on: Thu, 14 September 2017, 02:45:44 »
Yes, it is 6u, you may see the length on the top of the spacebar, which is in light green.
Offline William_S_Jones
  • Best Prime Ever!!!
« Reply #123 on: Thu, 14 September 2017, 05:00:44 »
Looking forward to this set hombre! Remember speaking w/ you on RMK, believe XDA is a great choice! I'm ready for your GB!
Offline kbdfans
« Reply #124 on: Wed, 20 September 2017, 05:26:32 »
very nice
Offline LastBrat
« Reply #125 on: Wed, 27 September 2017, 14:16:25 »
Love the planck set, it's enough to fill even my 5x14 ortho :)
One question about the spacebars: are all of them convex (even the 1u)?
Looking forward to seeing the samples.
Offline keebdeeb
« Reply #126 on: Wed, 27 September 2017, 23:07:55 »
INTERESTED! Voted on massdrop :)
Offline heliar_mk
« Reply #127 on: Sat, 30 September 2017, 04:42:55 »
Any News for these?
Offline hormbre
« Reply #128 on: Sat, 30 September 2017, 05:40:25 »
very nice
Thanks all ! Glad to hear that you like XDA Melon  :)
Any News for these?
We have been waiting for the samples ever since mid-July, which are supposed to be provided on August. However, the dye-sub manufacturer is busy with the orders which are much bigger than ours. Besides waiting for the samples, here is what we are doing :
1. Conmunicating with another manufacturer: Still need to confirm some details.
2. Join the Keycap Design Contest on MassDrop: Submitted, wait for the reply by MD.
We can understand your feeling, and we are trying our best to make XDA Melon come to us.
Thanks for your support and patience !
Offline hormbre
Re: [IC] XDA Melon ( Manufacturer changed, updated on Oct 27th )
« Reply #129 on: Fri, 27 October 2017, 08:02:11 »
Hey guys, sorry for no update during the last 2 month!
Due to delay, we have decided to change our manufacturer, and the new one also takes charge of producing XDA Canvas and GodSpeed.
We have dicussed about our design together, every key cap is possible to be produced except:
1. Two "7" ENTER Keys in ISO kit ,sorry to those who use ISO layout.
180975-0
2. 3.25U Spacebar, sorry to those who use Mistel keyboard.
181015-1
The new manufacturer will provide samples after Group Buys, and we will check them first to make sure the quality is up to the standard before mass production.
Thank you for your patience and support!
« Last Edit: Fri, 27 October 2017, 23:34:03 by hormbre »
Offline JSaintS
    • JSaintS
« Reply #130 on: Fri, 27 October 2017, 08:04:54 »
So if I understand that correctly no iso compatibility for this set right?
« Last Edit: Fri, 27 October 2017, 08:06:42 by eNrageDSainT »
Offline hormbre
« Reply #131 on: Fri, 27 October 2017, 08:09:03 »
So if I understand that correctly no iso compatibility for this kit, right?
ISO kit is still availble, just move out two Enter keys because of the capability limit to produce.
180973-0
Offline JSaintS
    • JSaintS
« Reply #132 on: Fri, 27 October 2017, 08:11:17 »
Oh ok, nice, I was scared. Glad I can still consider this set
Also, you mention samples after the GBs, you mean Canvas & Godspeed, right? Does anyone know when those two where supposed to be shipped? I'll go and check but just in case someone here knows
« Last Edit: Fri, 27 October 2017, 08:25:15 by eNrageDSainT »
Offline hormbre
« Reply #133 on: Fri, 27 October 2017, 08:36:02 »
No, I mean samples will be provided after our group buys. Canvas and Godspeed schedule could be found on MassDrop.
Offline senter
« Reply #134 on: Fri, 27 October 2017, 08:36:58 »
glad to hear you changed the manufacturer. I know it's a reliable one
Offline JSaintS
    • JSaintS
« Reply #135 on: Fri, 27 October 2017, 08:37:35 »
Oh nice! Do you know when that will happen (more or less)?
Offline hormbre
« Reply #136 on: Fri, 27 October 2017, 09:21:14 »
I hope so, thanks : )
We are working on this , will announce here as soon as the date is confirmed
« Last Edit: Fri, 27 October 2017, 09:46:02 by hormbre »
Offline hormbre
No, the length ending with "X" means it is concave, while ending with "U" means convex. So, all the 1X and 1.25X spacebars are concave, the other spacebars are convex.
« Last Edit: Fri, 27 October 2017, 23:54:49 by hormbre »
Offline fishpod
« Reply #138 on: Sat, 28 October 2017, 02:15:54 »
not a fan of XDA profile, but it's good news to hear that you are having the manufacturer of Canvas to do the job! :thumb: :thumb:
those canvas dye-sub turn out to be great
Offline Narandelar
« Reply #139 on: Sun, 29 October 2017, 16:37:49 »
Loving the look of this set and the fact that its XDA! I hope the group buy for this can start soon :D
Offline Niahi
« Reply #140 on: Sun, 29 October 2017, 23:12:19 »
Looks amazing
Offline JSaintS
    • JSaintS
« Reply #141 on: Tue, 09 January 2018, 15:41:52 »
Any update on this? I really really really want to see this happen!
Offline FailureToLoad
« Reply #142 on: Wed, 10 January 2018, 07:42:35 »
I've been looking for an XDA set to jump on, the fact that you have spacebar kits made this a no-brainer.
....And you know, no one makes XDA sets
Offline vincent88928
  • Have Fun Everywhere
    • YMDK
« Reply #143 on: Wed, 10 January 2018, 08:33:34 »
Updated on Oct 27th : 1. Manufacturer has been changed to the one produces XDA Canvas and XDA GodSpeed.       Thank you !
Updated on Jul 17th : Communicated with XDA manufacturer: 1. Use  five-side dye sublimation for light color legends keycaps & colorful legends keycaps. 2.Samples will be provided on August,  before Group buy starts. 3. Novelties kit optimized to be more systematic; Spacebar kit extended; Ortho/Planck kit added.   Thank you !
Updated on Jul 6th : 1.Spacebars kit has been extended as suggested.        Thank you for your support!
Updated on Jul 3rd :   1.We have decided to change the profile of Melon to XDA!  2.More kits & more novelties are available. We have designed 7 kits ,the planck kit will be added soon. 3. XDA Melon will be sold by kit.     Any questions and suggestions are welcomed!
Thank you for viewing!
Here comes a keyset designed by several mechanical keyborad fans from China. It is inspired by a cartoon character named Diana in Little Witch Academia, whose hair is almost the same color as hami-melon in China.
The original design:
Jul 20th: http://imgur.com/a/WMUZx
Jul 16th: http://imgur.com/a/DsRop
Jul 2nd: http://imgur.com/a/OR1Q2
Jun 14th:  http://imgur.com/a/zhRd2
Jun 11th:  http://imgur.com/a/wRAHQ
Jun 7th:    http://imgur.com/a/mX7MV
I would be grateful for any ideas or suggestions you have ,thank you very much !
UPDATED ON Jul 1st :  We are sorry to tell you that the group buy will not open on July 5th, because the collaboration with MAXKEY will not continue for some reasons!    Apologize for this again !UPDATED ON JUN 25TH:  1.Renders completed !2. Questionnaire of MAXKEY SA Melon Group Buy 3.Group Buy will open on Jul 5th ! Thank you !UPDATED ON JUN 15TH:   Design completed ! To avoid investing too much with few outputs, 1. Give up ~`   |\  in Mod's color , while retaining the number 0 in Alphas's color for a huger demand.  2.Reduce the colors of Novelties kit from 4 to 2, in order to get a lower price on this kit. 3. Working on renders now,will be updated soon.    Thank you !UPDATED ON JUN 13TH: 1.The color of Modifiers has been changed ,as well as the color of Novelties.  2. Open poll on MassDrop :
https://www.massdrop.com/vote/-Product-SA-Melon-keyset-produced-by-MaxKeysThank you !UPDATE ON JUN 11TH: 1.The color of Base has been changed for a more unified style. 2. Add an orange 1U ESC novelty .    Thank you !UPDATED ON JUN 10TH: 1.The color of 1U "0" in Non Standard Adapter kit has been changed to be the same as the color of alphas. 2. The font size of Enter key has been reduced to 2/3 of original to make it seem much simple and clean. 3. The size of the flower in Novelties has been reduced a little .    Thank you !UPDATED ON JUN 8TH: 1.The picture of non standard adapter kit has been added.   2.The SA profile is 112343.    Thank you !UPDATED ON JUN 7TH: 1.Design confirmed with pictures updated below(some non-stand keycaps will be added later), and renders are started to create.    2.Probably choose MAXKEY as manufacturer due to a shorter time to wait, as well as a lower price.    3.Groupbuy website preference: please tell us which one (except MD) do you like .    Thank you ! UPDATED ON JUN 4TH: We have connected MAXKEY, they are able to make this keyset unless: 1. A little change in novelties, such as no stripe in ESC and ENTER novelties. 2. MOQ >= 200. 3. must be sold as one set. The good news is that the price would probably under $100 exclude PP&shipping fee.Questionnaire of MAXKEY SA Melon Group Buy
Nice looking.
Have Fun Everywhere
Offline JSaintS
    • JSaintS
« Reply #144 on: Sun, 21 January 2018, 13:37:04 »
Back again (sorry for those who subscribed to this topic haha), but I would like to have an Update from OP! :D I really want that set to be real :D
Offline hormbre
« Reply #145 on: Sun, 21 January 2018, 22:08:21 »
Looks amazing
Nice looking.
Thanks for your support ! Now we are waiting for the renders which will be hopefully finished soon.
Offline hormbre
Re: [IC] XDA Melon ( Renders available, updated on Jun 10th 2018 )
« Reply #146 on: Sat, 09 June 2018, 21:38:50 »
Updated on Jun 10th 2018 : 1. Renders with keyboard are available now, thanks for the support of Thesiscamper, Fox Labs, CA66, Mechmini2.0.       Thank you !
197714-0
197717-1
197720-2
197722-3
197725-4
197726-5
« Last Edit: Sat, 09 June 2018, 21:42:43 by hormbre »
Offline kyoumau
« Reply #147 on: Sat, 09 June 2018, 21:50:07 »
Oh! I like this. Looking at it, It resemble too about my favorite fruit, the watermelon.
Offline darwinmclovin
  • Crivens!
« Reply #148 on: Sun, 10 June 2018, 05:57:40 »
Great to see the continuous development of your cool PBT custom set :thumb: I have been interested for a year now! Pls share your next milestones when you are able to and good luck!   :cool:
“We play and are played and the best we can hope for is to do it with style.” Sir Terry Pratchett -GNU STP -
Offline JSaintS
    • JSaintS
« Reply #149 on: Sun, 10 June 2018, 06:02:55 »
Glad to see you're still committed to this!
Hopefully that will come soon! :D
