Author Topic: Cheapest Cherry Mx black board ?  (Read 1518 times)
Offline plerd
« on: Fri, 02 June 2017, 09:09:03 »
What's the cheapest cherry mx black board that is either 10 keyless or full size 104 with aluminium case ? i have had trouble finding a cheap aluminium case keyboard.
Offline LiquidEvilGaming
    • LiquidEvilGaming Youtube
Re: Cheapest Cherry Mx black board ?
« Reply #1 on: Sun, 04 June 2017, 11:57:09 »
Generally that's because an aluminum case raises the price quite substantially.  If you want a cheap MX black option i'd really recommend dropping that requirement.
Current Daily Driver/s
White Leopold 750R MX Reds
Head of LiquidEvilGaming on Youtube
i7 4790k/16GB DDR3/GTX 1060 6GB SSC/256GB Samsung SSD/2TB SSHD/W10
« Reply #2 on: Sun, 04 June 2017, 12:26:54 »
The other thing to note is that a cheap aluminum case will look like a cheap aluminum case, you won't find a great alu case for a dirt cheap price. You either need to go all in and spend the extra money to do it right or buy a plastic cased board and upgrade later.
