Author Topic: SP DSA spacebar not working with cherry stabs.  (Read 1621 times)
Offline Encabulator
« on: Fri, 02 June 2017, 09:16:39 »
I really don't know how to explain what's going on. all the other stabilized keys work fine but the spacebaar refuses to snap onto the dummy stems. The spacebar didn't look warped, if there is any its very tiny. It was using sentraq stabs, but they are currently being replaced with authentic cherry stabs. Anyone have similar issues?
relax bro.. no one will bite ur head off on geekhack.. this is not that kind of community...   hahahahahahaha
Though tp4 will personally chew you out if you start selling $60 orings.
Offline Hyde
  • White Tofu Extraordinaire
Re: SP DSA spacebar not working with cherry stabs.
« Reply #1 on: Mon, 05 June 2017, 13:04:52 »
There was a thing before about DSA or SA profile spacebar being 1mm off on their side stems.
Which is normally fine on Costar stabs but will be an issue on Cherry stab.
Contact Signature Plastic or ask the seller if you can get a new spacebar.
Offline Tactile
« Reply #2 on: Mon, 05 June 2017, 17:32:58 »
You can check the proper dimensions here.
REΛLFORCE
