Author Topic: red ESC key and blank WASD keys for HHKB?  (Read 3265 times)
Offline obazavil
« on: Thu, 25 February 2010, 18:45:36 »
Hi!
Where did you guys bought those keys from?
I want to buy those for my HHKB Pro 2, but no idea where to look.
Offline ricercar
  • mostly abides
« Reply #1 on: Thu, 25 February 2010, 18:50:00 »
The Filco boards from EliteKeyboards.com come with a red ESC and a red FILCO key.
Offline obazavil
« Reply #2 on: Thu, 25 February 2010, 19:11:04 »
they also have for hhkb :) nice site :P
Offline ricercar
  • mostly abides
« Reply #3 on: Thu, 25 February 2010, 19:22:06 »
What's the diff between a HHK and Filco cap? Is one deeper/taller?
Offline obazavil
« Reply #4 on: Thu, 25 February 2010, 19:24:25 »
well. since hhkb and filco uses 2 different keys, i dont think is a wise idea to mix them (that apart from the idea that maybe doesnt fit neither)
Offline NOMiS
    • http://teamvga.com
« Reply #5 on: Thu, 25 February 2010, 19:26:09 »
Quote from: ricercar;160741
The ones you linked are for Alps. They will not fit Cherry MX or Topre. They have different stems.
Steelseries Xai
Poker X KBC (Red)
Offline ricercar
  • mostly abides
« Reply #6 on: Thu, 25 February 2010, 19:27:38 »
Zero-compatible means alps-compatible, and HHK means Cherry?
Offline obazavil
« Reply #7 on: Thu, 25 February 2010, 19:30:45 »
HHKB = PFU Happy Hacking Keyboard Pro 2
Offline itlnstln
« Reply #8 on: Thu, 25 February 2010, 19:49:18 »
Quote from: ricercar;160753
The Zero is the ALPS-based Filco and the HHKB uses Topre switches. The Filco Majestouch has Cherrys.
