Author Topic: TADA68 Opinions  (Read 2766 times)
Offline Vapouriser
TADA68 Opinions
« on: Fri, 02 June 2017, 16:35:29 »
Hi
Was thinking about adding the TADA to my line up, but have no experience of GAT switches. I like switches on the heavier and clickier side. Switches in stock on the TADA are Gateron blue/black and brown.
Any opinions or experience with these switches OR the board would be most welcome.
Offline AGscooby
Re: TADA68 Opinions
« Reply #1 on: Fri, 02 June 2017, 17:02:23 »
Gateron blacks are quite springy and tiring for light switch users (like me). They're a pretty smooth linear feel though. Brown tactility is nice but subtle and unobtrusive. Haven't had the pleasure of the blue clicks yet.
Re: TADA68 Opinions
« Reply #2 on: Sat, 03 June 2017, 00:03:19 »
I believe gat greens are also an option. I got mine from OCO (the saber 68) and got gateron greens. I don't know much about keyboards in general, but I do know that I absolutely love my tada68. I programmed it with macros that save me so much time. Plus, the enjoypbt keys are just wonderful.
As for the gateron greens; at first, it was a weird transition from cherry MX blue, but, after using it for a while, I can safely say that I prefer it over the MX blues. The greens have a smoother feel, while still keeping that tactile Sound.
Hope this helps
Sent from my LG-H918 using Tapatalk
Offline SBJ
  • Tactile pls
Re: TADA68 Opinions
« Reply #3 on: Sat, 03 June 2017, 01:08:51 »
I second the Gat Green switches - if you prefer your switches heavier.
Offline Zhuni
Re: TADA68 Opinions
« Reply #4 on: Sat, 03 June 2017, 04:15:54 »
Got one with reds. Much smoother then cherry. The stock caps are perfect. Would of happily paid more for it. Best value board I've ever bought.
[sigpic] [/sigpic]
KBC Poker
Offline brianjking
  • always carry a towel.
    • @brianjking
Re: TADA68 Opinions
« Reply #5 on: Mon, 05 June 2017, 13:28:53 »
I had one with Gateron Browns and will definitely say these are MUCH better than their Cherry counterpart. However, I had it switched over to 67g Zealios and enjoyed the board much more that way.
The aluminium cases are definitely top notch, however, I honestly like my boards to be a bit portable and subsequently never bought into the upgraded case and found the plastic to be just fine. Definitely a great board for the price.
