Author Topic: Unicomp Customizer Some Keys not Working  (Read 11079 times)
Offline Genie
« on: Fri, 26 February 2010, 02:57:00 »
Hi ppl,
I have Unicomp Customizer 104/105 keyboard and after spilling some really small amount of water on it and then shaking it to get the drops out of the keys,  some keys stopped working (like F2, F4 , F6, 5, 6,7 and 8). the rest are working fine.. I have opened the case, cleaned everywhere and still bummer... Those keys are not working...
Any advice?
Thank you!
Offline Half-Saint
« Reply #1 on: Fri, 26 February 2010, 03:02:12 »
I presume you've left it to dry completely?
Cheers
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline Genie
« Reply #2 on: Fri, 26 February 2010, 03:39:04 »
yup I did leave it first to dry (24 hours and more) and then opened it and cleaned it completely....
Offline Half-Saint
« Reply #3 on: Fri, 26 February 2010, 04:13:13 »
Exactly which part of the keyboard did you spill? :)
[SIGPIC][/SIGPIC]
Offline Genie
« Reply #4 on: Fri, 26 February 2010, 05:00:40 »
upper left part :)
lets say from ESC key to ASD
I mean I have tons of keyboards at home and at some point I did spill something on every single one of them :) but this one is first to half-die after it..
And as I said I really did not spill much (and it was water , other keyboards were not so lucky :D)
Offline spolia optima
« Reply #5 on: Fri, 26 February 2010, 09:14:43 »
Quote from: ripster;160858
...as long as you don't spill anything too toxic into the keyboard.
like 2-part epoxy?
D:
keyboards!
Offline Genie
« Reply #6 on: Fri, 26 February 2010, 12:58:47 »
well the thing is that that incident was like 3 months ago and keyboard is still not working  :(
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Fri, 26 February 2010, 13:01:28 »
I suppose if it was really, really HOT (like, boiling) water or coffee or something there'd be a risk of it melting the membrane sheets...but without that being the case, I can't think of a logical reason why it doesn't work.
kishy.ca
Offline brkz
« Reply #8 on: Sat, 27 February 2010, 08:43:28 »
I would open it up and separate and clean the membranes. A single hair in there can be enough to make it not work. Water may still be trapped in between the membranes.
Offline lal
« Reply #9 on: Sun, 28 February 2010, 06:09:50 »
Without breaking rivets I'd try to force any left water out by carefully applying heat for some time.  Like storing the inner assembly near the room heater for some days.
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #10 on: Sun, 28 February 2010, 09:58:22 »
If they keys aren't working, as opposed to keys spontaneously pressing themselves, drying it out shouldn't make a difference one way or the other. Moisture would be completing circuits not disabling them.
That's opinion based on fact, but hey, maybe keyboards can defy physics?
kishy.ca
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #11 on: Sun, 28 February 2010, 10:26:13 »
Yeah, we learned that in...grade 12 physics maybe? Either that or some other high school science class.
I seriously doubt the water in question here was distilled, and even if it was the dust and other material likely in the keyboard would cause it begin conducting.
kishy.ca
Offline Mental Hobbit
« Reply #12 on: Sun, 28 February 2010, 12:39:51 »
Could a short on the controller board kill some keys? Sounds unlikely to me... but I don't see how a little sip of water could get into the membranes of a Unicomp and do permanent damage there. Unless it was rather a flood than a sip, it can't have gone through the barrels, so it would have had to crawl through the membranes from the bottom side up. But problems should have started at the bottom key row then, not at the F-keys.
Typing on blues.
Offline ricercar
  • mostly abides
« Reply #13 on: Sun, 28 February 2010, 17:31:55 »
Do not use Windex to clean membrane sheets. It strips the traces right off.
Offline bombcar
« Reply #14 on: Sun, 28 February 2010, 21:48:59 »
Somewhere I think I have my old broken Unicomp Customizer  (actually customized!) - if I find it I will let you know.
This was before Mac OS X allowed easy remapping of key locations.
Offline Genie
« Reply #15 on: Mon, 01 March 2010, 15:09:18 »
well I had to remove the rivets and clean the membranes with alchocol.... now.. I need to use screws.....
Offline Genie
« Reply #16 on: Wed, 03 March 2010, 10:26:21 »
thank you on your advice I did just that... :)
I really didn't want to find myself with non working keys and tightly screwed keyboard :D
Offline Genie
« Reply #17 on: Thu, 04 March 2010, 06:35:23 »
yup working now! and it better should .. I really almost loose my nerves trying to get it back right ...:)
Offline hyperlinked
« Reply #18 on: Thu, 04 March 2010, 06:46:40 »
Quote from: Genie;160802
Hi ppl,
Looks like the H20 knocked out your 'E' and 'O' keys too. Not to worry, just buy a vowel. They're cheap.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
