Author Topic: Keys flying off  (Read 3892 times)
Offline jb
Keys flying off
« on: Sat, 03 June 2017, 20:23:01 »
So I have this here Asus ROG Claymore Core keyboard, which is a tenkeyless thing with Cherry MX Brown switches...
Some of the keycaps fly off if I flick them with too much excitement! For example, when I arrow down repeatedly, I left my finger slide off the key, which sends the key back up very quickly. After a few of those quick flicks of the key, the keycap flies off. :( It's not all the keys, just a few, but the down arrow is one of the worst offenders.
I thought about gluing the keycap onto the switch, but that seems too permanent, so I jammed some paper in the keycap hole. This seems to work, but it makes me a little sad that I had to do this.
My question is.. are keycaps flying off of the switch stem a common phenomenon? What's the best solution?
Offline Tactile
Re: Keys flying off
« Reply #1 on: Sat, 03 June 2017, 21:21:05 »
Buy a replacement set of caps. Yours are apparently out of spec.
REΛLFORCE
Offline Lazylewis
Re: Keys flying off
« Reply #2 on: Sat, 03 June 2017, 21:46:57 »
I've never had a keycap fly off, ever.
Offline rioc
Re: Keys flying off
« Reply #3 on: Sat, 03 June 2017, 22:45:33 »
Quick solution is to put a small square of Scotch tape on the stem and push the cap on
Sent from my MHA-L09 using Tapatalk
Offline Targa-TV
Re: Keys flying off
« Reply #4 on: Sun, 04 June 2017, 10:12:35 »
Strangest keycap issue I've read. The stem must have been molded very poorly.
Filco MJ2 Black - MX Red | VA88M - MX Brown | Cherry G80-3000 -
  MX Blue | Cherry G80-3000 - MX Black | XD75re - MX Silent Red
[image]http://i.imgur.com/our8YUc.png[/image]
Offline Auk
Re: Keys flying off
« Reply #5 on: Sun, 04 June 2017, 10:44:00 »
Damned if I can find it right now, but there is a video on YouTube or somewhere showing a similar  problem Logitech. Might've been the new G Pro TKL, but the guy making the video showed how repeatedly striking a particular key would cause it to come loose and be catapulted off the switch.
Cheap OEM caps to blame?
Offline f32h80fsd08h34r5
Re: Keys flying off
« Reply #6 on: Sun, 04 June 2017, 12:41:39 »
Do you like that keyboard? If it were me I would just start saving for a new one.
But everyone has their preference  :thumb:
Re: Keys flying off
« Reply #7 on: Sun, 04 June 2017, 12:59:41 »
Not really the strangest thing, all of my keysets have slightly different fitment/tightness on the same board.
It is a little weird that a stock board has this issue though, but I guess jb's method of pressing the arrow is prone to making this happen.
Offline Targa-TV
Re: Keys flying off
« Reply #8 on: Sun, 04 June 2017, 13:49:43 »
So it may be excessive pressure on the keycap at a certain angle... Damn, jb can't even ask for a refund in that case.
 But even so, the plastic or the molding must be absolute s* to fly off...
And they have the gall to sell that thing. Incredible stuff.
