Author Topic: M13 Key Swap w/ Term F / Term M  (Read 3969 times)
Offline sethstorm
« on: Fri, 26 February 2010, 20:51:56 »
Since no other source has yet to yield the proper keys, I've gone on and done the swap between my Terminal F and M13, along with some keys swapped to/from a Terminal M.
Hopefully (for those M13 fans) that this does not go against any existing orthodoxy.
Yes, there are spots missing/inconsistent, but overall, it doesn't get to be that bad.  Not only do you get the color change, the M13 space bar provides a more solid key thanks to a larger stabilizer.
Notes:
Should the reader want to do a swap, mind that you will have to swap:
  • Space Key from a Model M
  • Plastic Holders from the M13 for the Backspace/Right Shift/Num Enter keys
  • An appropriate number of blank blacks to cover the missing spots.
  • G/H keys from a rare M13 white, or chisel out your own.
  • Another keyboard that has the G/H but requires chiseling
  • A good-size supply of blank blacks.
Keys that probably won't be swapped:
  • European style Enter.
Unless someone has such a key in black, even blank, this one isn't going to leave the keyboard.  I highly doubt that ISO Enter was ever put on an M13 - if it is, it the most rare M13 on the planet.
[/LIST]
Keys that need swapped:
  • G/H as stated above
  • A black left shift key of appropriate width
  • PF3-PF24 with blank blacks
  • Replacement Enter/Backslash from a Model M.
  • Rule Home w/ blank black.
  • Other keys that might make the M13 look more consistent.
Pictures:
The Super Carrier.  Note the G/H are coincidental and wasn't my choice.
The M13.  Same thing w/ the G/H keys.
As a followup question, where might one get a good source of blank black keys? I've heard of Unicomp and Fentek, but no definite answer.
« Last Edit: Fri, 26 February 2010, 20:59:56 by sethstorm »
Current:
IBM: Model M: 1391401, 1386887 Terminal 122 Key
IBM: Model F: 6110668 Terminal 122 key with Trackpoint and M13 blacks
IBM: Specialty: Wheelwriter 5, Boltmodded.  AT F layout, M technology.
Lexmark/IBM: M13 Black Trackpoint
NCR:HO150-STD1-01-17 Decision Mate V - The other Gray NCR linear.
Offline sethstorm
« Reply #1 on: Fri, 26 February 2010, 22:52:40 »
Quote from: ripster;161080
For Black Blanks click on the Black Unicomp Spacesaver Mod link in my sig.  $20.
No way to get them w/o a keyboard? I'm not sure that they'd understand if I added it to a keypad order.
« Last Edit: Fri, 26 February 2010, 23:04:13 by sethstorm »
Current:
Offline sethstorm
« Reply #2 on: Sat, 27 February 2010, 03:57:35 »
Quote from: ripster;161082
Just give them a call - they'll sell the keys separately.
Will do on the next business day - they shouldn't be more than a day away, even by ground.
Quote from: ripster;83063
P.S. These keys were designed for the Unicomp with the IBM pointer (we used to call them Barbie's nipple in the office before HR found out).  You will see a couple of keys (for G and H position) with a rounded edge.  No biggie - it's very subtle and helps you get a visual on centering your hands.
Hopefully this is still true - then it just means I have a blank spot for my G/H.
Current:
Offline Specter_57
« Reply #3 on: Sat, 27 February 2010, 21:08:42 »
Those black keys on that terminal keyboard look pretty sharp.
The G & H keys...well...maybe hack in the trackpoint to the terminal board...?
Just a thought....
Spec57
Offline sethstorm
« Reply #4 on: Sun, 28 February 2010, 12:19:08 »
Quote from: Specter_57;161215
Just a thought....
Spec57
Now if I could get the trackpoint assembly separate from an M13, that would be feasible. The buttons would require a white M13 donor and another Terminal Model F case.  While those are rare, they do make that a tempting route.  There is no membrane to worry about, and the attachment appears not to be as sturdy as I thought it would be.
The space otherwise appears to be there.
Current:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Sun, 28 February 2010, 12:23:46 »
Terminal Model M case top should work...those often aren't as costly.
I think the screw placement is the same.
kishy.ca
Offline sethstorm
« Reply #6 on: Sun, 28 February 2010, 15:48:22 »
Quote from: kishy;161248
Problem is that the only spare I have in that regard is cracked.  Not enough to be visible, but enough to know that the Terminal Model M case is a bit more flimsy (if by a little) than the Terminal Model F.
Sure they'd fit, even w/ the two-piece arrangement of the top case?
« Last Edit: Sun, 28 February 2010, 15:50:49 by sethstorm »
Current:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #7 on: Sun, 28 February 2010, 15:55:30 »
I don't have the Model F, but from photos I see no differences at ALL in the top halves of F vs M.
kishy.ca
Offline sethstorm
« Reply #8 on: Sun, 28 February 2010, 16:51:57 »
Quote from: kishy;161260
Makes me think if you could gut a non-working F for the metal backing and strain relief for a Model M in the F case.
Current:
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #9 on: Sun, 28 February 2010, 16:54:12 »
I don't know how the guts attach onto the metal backing of the F...it's probably possible.
Model Ms do have strain reliefs btw.
We just won the hockey game!
kishy.ca
Offline sethstorm
« Reply #10 on: Sun, 28 February 2010, 17:09:15 »
Quote from: kishy;161279
Not removable ones as in the case of the terminal boards - they're part of the cable.  For the F, it's part of the frame. If the Model M attaches to the top (versus the bottom), you could have a very mod-friendly terminal board case.  That, and you can easily rework the jumper block(remove it) to accept a USB connector. While not in the most optimal spot, it saves drilling into the case.
« Last Edit: Sun, 28 February 2010, 17:13:35 by sethstorm »
Current:
Offline Specter_57
A trackpointer hack...
« Reply #11 on: Sun, 28 February 2010, 17:26:26 »
The idea of possibly doing a trackpoint hack on a terminal keyboard is becoming more and more appealing...and should be possible to salvage one from a junked laptop...but as others in other threads have lamented...information on the trackpoint is rather difficult to get hold of.
So many hacks...so little time...(and info...)  ha!!
Spec57
Offline ch_123
« Reply #12 on: Sun, 28 February 2010, 20:24:24 »
Have fun fitting the buttons on...
Offline Specter_57
« Reply #13 on: Sun, 28 February 2010, 21:10:04 »
Quote: "Have fun fitting the buttons on...."
Never said it would be easy....but already have come up with a couple of ideas on how to.
Spec57
« Last Edit: Sun, 28 February 2010, 21:13:39 by Specter_57 »
