Author Topic: I'm new here  (Read 2321 times)
Offline hii915
I'm new here
« on: Thu, 08 June 2017, 19:09:16 »
I'm new (ish) here and im coming from r/mechanicalkeyboards and r/mechmarket.  I've been lurking there for months.  I need some recommendations for my first mech (or keyboard becuase I don't have either).
Also, as far as keyboard's go I am looking for a decent 60% or 75%.  As keycaps go I like the 1976 set or the tai hao sets.  My budget is 160-170 usd.  Thanks!
Pictures:
« Last Edit: Thu, 08 June 2017, 19:17:55 by hii915 »
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: I'm new here
« Reply #1 on: Sat, 10 June 2017, 18:30:29 »
Welcome :)
For the keyset you'll probably wanna go with the Tai Hao one unless there are other caps you like.
The SA set alone will most likely surpass your budget.
