Author Topic: Zeal60 caps lock indicator backlight  (Read 1762 times)
Offline Teacob
« on: Sat, 10 June 2017, 06:13:16 »
Reposted from Reddit as I've had no response there;
I've been enjoying the Zeal60 for a while now, but I've noticed that some small features are missing for me.
There is supposed to be LEDs indication when
* the caps lock is on
* different function layer is activated
Both of these don't work for me with any of the keymaps in Wilba's Zeal60 fork (https://github.com/Wilba6582/qmk_firmware/tree/zeal60) of the qmk software. I've been using the V0.6 firmware that was released in April this year and the capslock/function layer indication was added in v0.4
But otherwise, it seems like everything else is working. I can switch between backlight profiles, I've successfully edited and flashed my own keymap. Everything works apart from these two small features, but some visual feedback when the caps lock is on would be awesome and the same goes when switching layers.
Anyone else experience this? I have a sneaking suspicion that maybe this isn't active by default and can only be activated using the Windows-only command line tool (https://github.com/Wilba6582/zeal60) which would suck, I only have access to OSX and Linux distros.
« Last Edit: Sat, 10 June 2017, 06:20:43 by Teacob »
Offline Cados
Re: Zeal60 caps lock indicator backlight
« Reply #1 on: Mon, 19 June 2017, 10:27:28 »
I have the same issue. Prior to Zeal60 v06 the LED would indicate when the capslock was turned on.  :(
Zeal60 - Zealios 78g
HHKB Type 2
