Author Topic: [GB] UK78 - 60%+Numpad [Completed] *UPDATE* PCBs and R2 plan  (Read 285688 times)
Offline FearsomeCubedWarrior
  •  Post Reporting Timeout
Re: [GB] UK78 - 60%+Numpad - Order Placed
« Reply #200 on: Fri, 21 July 2017, 19:57:32 »
« Last Edit: Mon, 15 April 2024, 18:34:32 by FearsomeCubedWarrior »
Offline kmba
  • Formerly tameone
« Reply #201 on: Fri, 21 July 2017, 21:45:16 »
Lazer.  This blue case screams for blue themed caps, and cherry profile > dsa.
keyboards.
Offline TheBestUkester
« Reply #202 on: Sat, 22 July 2017, 00:24:53 »
Will the PCB support the Panda/Outemu hot swap sockets?
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
« Reply #203 on: Sat, 22 July 2017, 03:16:48 »
Sooo, what will be the better option with dark blue UK78: complicated white alps with DSA Lightcycle or Zealios 78 with GMK Lazer?
Laser. Has to be.
Personally going to strip mine and re-powder coat it tho for a special project.
Offline rozakiin
  • British Custom Anyone?
    • UK Keyboards
« Reply #204 on: Sat, 22 July 2017, 05:13:02 »
If they are like hotlites then the majority of the position should work but the Modifier row won't
Offline forumusername
« Reply #205 on: Sat, 22 July 2017, 15:13:17 »
Is there a difference in these hot swap sockets and the hotlites that can be purchased separately?
Edit seems that they work roughly the same but are smaller which could be advantageous based on what rozakiin said on modifier row.
I am leaning towards getting some and modding them with a tactile switch.
« Last Edit: Sat, 22 July 2017, 20:56:43 by forumusername »
« Reply #206 on: Sun, 23 July 2017, 10:24:23 »
Yea, I’ll pick up some purple Outemu’s as testers for Clear stem swapped Panda’s. Don’t want to sink all the moola if they won’t work.
« Reply #207 on: Sun, 23 July 2017, 13:37:12 »
I read a bit more last night and they don't work like true hotlites in that other switch housing will not work with them. There were a few people on Reddit saying that panda housing zelio stems were amazing but panda housings aren't made for RGB 😥.
Are the purps made for RGB?
Offline clickstops
« Reply #208 on: Mon, 24 July 2017, 09:29:07 »
Thanks for posting the dimensions!
I'm doing an ALPS board and thus probably using Granite even though I don't love typing on DSA. (DSA + ALPS tactile > Cherry + MX tactile though.)
Wondering if that marble royal glam wrest in TKL size will look stupid being about 3cm too narrow. What do you guys think? White marble + silver "fjell" case + granite sounds nice. But half an inch on each side sounds pretty uggo =/
Offline rozakiin
    • UK Keyboards
« Reply #209 on: Mon, 24 July 2017, 11:06:03 »
The besel is what would be not be covered by the rest, I don't think it would look too out of place.
« Reply #210 on: Mon, 24 July 2017, 13:43:34 »
Yup. Switchtop just started carrying the clear versions. Look like Zealios.
Offline Anakey
« Reply #211 on: Mon, 24 July 2017, 14:14:58 »
at least you got the TLK one, I only got a 65% as originally was going to be for a subatomic but meh might get a longer one next time and see if i can sell my 65% one
Offline clickstops
« Reply #212 on: Mon, 24 July 2017, 14:24:40 »
Good point. Thanks!
Offline rozakiin
    • UK Keyboards
« Reply #213 on: Fri, 28 July 2017, 07:33:40 »
Nothing to update people on, all parts are on track to be with me by 14th August, I have attached photos sent to me from the PCB manufacturer for QC checking.
174426-0
174428-1
    • Jae | Top Clack
« Reply #214 on: Fri, 28 July 2017, 07:44:41 »
Looking good :)
Offline Petch
« Reply #215 on: Fri, 28 July 2017, 08:05:27 »
That blue! Almost regretting getting the full base now haha
Also wishing I ordered an extra pcb and albs plate - I'm guessing you didn't order extras?
« Last Edit: Fri, 28 July 2017, 08:07:13 by Petch »
Offline rozakiin
    • UK Keyboards
« Reply #216 on: Fri, 28 July 2017, 08:29:31 »
Couple of extra pcbs and plates, they will be available at the same time as shipping.
Offline kmba
  • Formerly tameone
« Reply #217 on: Fri, 28 July 2017, 08:40:06 »
blue PCB.. awesome.  Blue case, blue caps (nautilus), blue pcb.. but not blue switches.  Halos if I like them, otherwise 78g pandalios.
keyboards.
Offline Petch
« Reply #218 on: Fri, 28 July 2017, 08:48:42 »
Cool,I'm down for an extra pcb + brass alps plate if there are any :)
Is there any more info on halos? I tried getting asking them if they were going to sell them individually and they said no plans until after the kickstarter
« Reply #219 on: Fri, 28 July 2017, 12:15:03 »
« Last Edit: Mon, 15 April 2024, 18:34:43 by FearsomeCubedWarrior »
Offline kmba
  • Formerly tameone
« Reply #220 on: Fri, 28 July 2017, 13:16:31 »
I don't think anyone knows exactly when and where the Halo switches will be available individually. Aside from them saying they will be at some point.  Early reviews say they're different, but not quite what was expected so I think we'll really just need to try em for ourselves..
keyboards.
Offline MMKB
« Reply #221 on: Fri, 28 July 2017, 15:25:57 »
If rozakiin is okay with a transfer, I'm willing to let go of my order. Thanks.
Fjell Top Case
Colour:446C
Diffuser
SS MX Plate
Assembled PCB
Bumpons, screws, shipping of case
(more details to come if this is doable)
Offline rozakiin
    • UK Keyboards
« Reply #222 on: Sat, 29 July 2017, 08:39:17 »
Fjell Top Case
Colour:446C
Diffuser
SS MX Plate
Assembled PCB
I am OK with transfers, both parties email me at ukkeyboards@gmail.com stating order number, username on the form and address.
« Reply #223 on: Sat, 29 July 2017, 13:50:35 »
« Last Edit: Mon, 15 April 2024, 18:35:01 by FearsomeCubedWarrior »
Offline Petch
« Reply #224 on: Sun, 30 July 2017, 18:18:12 »
Are bumpons/screws something we had to ask for separately?
Offline rozakiin
    • UK Keyboards
« Reply #225 on: Sun, 30 July 2017, 18:19:52 »
No that's all included, not to worry.
Offline rozakiin
    • UK Keyboards
« Reply #226 on: Thu, 03 August 2017, 11:32:07 »
Another Small Update:
Cases have been milled and are going on to anodising and sandblasting, manufacturer sent through a photo showing the sample case to show how the colour matching is and the logo engraving. The colour for the sample is Pantone 5265C and came out slightly too dark so the colours will be made lighter to get closer to the intended colour.
174904-0
Offline ectoplasmatic
« Reply #227 on: Thu, 03 August 2017, 11:41:38 »
So exciting Roz! Thanks for all the updates. Looking really good!
Offline Petch
« Reply #228 on: Thu, 03 August 2017, 15:05:04 »
Thanks for the update. Will the colour change cause any delays?
« Reply #229 on: Thu, 03 August 2017, 15:06:15 »
« Last Edit: Mon, 15 April 2024, 18:35:22 by FearsomeCubedWarrior »
Offline rozakiin
    • UK Keyboards
« Reply #230 on: Thu, 03 August 2017, 15:07:49 »
No delay as they haven't been anodised yet.
Offline ChitownM2
« Reply #231 on: Thu, 03 August 2017, 21:00:41 »
Looking good. Can't wait to get this.
Offline kmba
  • Formerly tameone
« Reply #232 on: Fri, 04 August 2017, 06:42:03 »
Oh man.. hype train. I'm selling a bunch of my MX based boards and buying more topre due to the sweet ass cases and replacement domes that are coming out soon, but the uk78 will not be going anywhere. One of three I will be keeping!
keyboards.
« Reply #233 on: Fri, 04 August 2017, 20:12:30 »
Can't believe how fast this keyboard is getting done. Awesome work!
Offline rozakiin
    • UK Keyboards
« Reply #234 on: Mon, 07 August 2017, 04:48:44 »
Hi everyone,
I have just added UK78 support to the QMK Repo
If you need the Caps Lock LED to work on your UK78 then you will need to use this build as the online QMK tool http://kbfirmware.com/ configures the LED incorrectly otherwise here is the json for the online tool.
« Reply #235 on: Mon, 07 August 2017, 07:58:20 »
Legend!!!
Offline SBN
« Reply #236 on: Mon, 07 August 2017, 10:45:49 »
Thank you for the work and effort! Great stuff! :)
Offline ojrask
  • juuh elikkäs
« Reply #237 on: Mon, 07 August 2017, 13:50:43 »
Hi everyone,
Awesome! Is adding a baseline Winkeyless (7u spacebar and 1.5u mods) layout a big chore? I presume the uk78.h file needs another structure to create the proper matrix for the keybindings?
Current:
Coming up:
IC/GB:
Offline rozakiin
    • UK Keyboards
« Reply #238 on: Mon, 07 August 2017, 16:16:51 »
Hi everyone,
7u and 1.5u mods can be created from the file currently, the structure is made to have the max number of keys so all layouts can be made without editing the matrix.
Offline vinzlr
« Reply #239 on: Mon, 07 August 2017, 16:31:16 »
Has anyone opted out/wished to sell their spot? I'd love to get in on this :O
Offline ojrask
  • juuh elikkäs
« Reply #240 on: Mon, 07 August 2017, 17:01:35 »
Hi everyone,
I see, thanks for clarifying. Need to tinker when the board arrives then. :)
Current:
Coming up:
IC/GB:
« Reply #241 on: Mon, 07 August 2017, 21:39:25 »
Rozakiin you are the best.
I can't figure out what switches I want to get for the boards I ordered.  I am itching to get some zandas but then the housing will be bad for the LEDs :'(
Kbdfans is running a gb for milky gat switches that look like fun too.  Decisions decisions.
« Reply #242 on: Tue, 08 August 2017, 02:18:44 »
Yeah I'm trying to decide between the milky gats and kailh box linears... tough decisions!
Offline SBN
« Reply #243 on: Tue, 08 August 2017, 11:37:33 »
Maybe this is a chance for you?
https://geekhack.org/index.php?topic=86839.msg2335666#msg2335666
« Reply #244 on: Wed, 09 August 2017, 08:38:03 »
I can’t quite tell, is there enough room between the PCB and the bottom for screw in stabs? I looks like it, but ya know... measure twice and all.
Edit: I’m guessing we’ll need to use washer or tape on the PCB for the screws as well.
« Last Edit: Wed, 09 August 2017, 08:55:59 by TheBestUkester »
Offline AlexAtPanc
    • Panc Interactive
« Reply #245 on: Wed, 09 August 2017, 09:12:10 »
This looks super-cool, sad this one completely missed my radar!
Offline Petch
« Reply #246 on: Wed, 09 August 2017, 09:20:25 »
I asked previously, either here or in the IC check thread. They will fit but yeah, you'll need some washers. I'll try find the ones I got on ebay
« Reply #247 on: Wed, 09 August 2017, 09:29:14 »
I’ve got some Cherry ones, just wanted to triple check! Thanks for the heads up dude.
Offline Petch
« Reply #248 on: Wed, 09 August 2017, 09:34:29 »
http://www.ebay.co.uk/itm/M2-M2-5-M3-M4-M5-M6-M8-M10-M12-WHITE-NYLON-FLAT-FORM-A-WASHERS-PLASTIC-WASHER/231172710368?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
These are the washes I got, I think M2 or M2.5  (can't remember and ebay won't tell me)
Offline rozakiin
    • UK Keyboards
« Reply #249 on: Wed, 09 August 2017, 09:54:54 »
Only one maybe two stab positions will need tape, I have my test pcb with screw in stabs without issues.
