Author Topic: [IC] Fox-orange 80% Custom TKL UPDATED PICTURES !!!  (Read 34705 times)
Offline senter
Re: [IC] Fox-orange 80% Custom TKL (Arc)
« Reply #50 on: Tue, 20 June 2017, 07:30:21 »
Split backspace, QMK support? :)
We will consider it
Offline zl_ramiel
« Reply #51 on: Tue, 20 June 2017, 09:37:00 »
The white prototype looks different from all the color options in your link. Is that made by microarc oxidation?
Offline oluigenuma
« Reply #52 on: Tue, 20 June 2017, 11:00:57 »
+1 for qmk support
Have you considered a brass plate?
« Last Edit: Tue, 20 June 2017, 11:04:34 by oluigenuma »
Offline N0GLUT0N
« Reply #53 on: Tue, 20 June 2017, 11:07:31 »
+1 for split backspace.
Offline 19820815
« Reply #54 on: Tue, 20 June 2017, 14:30:13 »
split backspace    +1
Offline senter
« Reply #55 on: Tue, 20 June 2017, 18:35:29 »
+1 for qmk support
Of coz,brass plate is allowed
Offline senter
« Reply #56 on: Tue, 20 June 2017, 21:31:06 »
+1 for qmk support
   Fully Programmable using Bootmapper Client
Offline senter
« Reply #57 on: Wed, 21 June 2017, 05:40:55 »
Offline jacky
« Reply #58 on: Wed, 21 June 2017, 08:18:40 »
I made computer wallpaper with this picture  ;D ;D
Offline ppp
  • KappaKeepoKoopa
« Reply #59 on: Wed, 21 June 2017, 08:39:52 »
Offline senter
« Reply #60 on: Wed, 21 June 2017, 11:27:38 »
Good job :D
Offline doom2
« Reply #61 on: Wed, 21 June 2017, 15:31:46 »
Looks nice! Where is it being made?
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #62 on: Wed, 21 June 2017, 19:00:37 »
Is there any specific reason for the gap between the 2 layers?
Offline senter
« Reply #63 on: Wed, 21 June 2017, 20:46:04 »
China.bro
Offline doom2
« Reply #64 on: Wed, 21 June 2017, 21:25:48 »
China.bro
Oh nice! Is there a qq group?
Offline senter
« Reply #65 on: Wed, 21 June 2017, 21:33:14 »
China.bro
Yes.425307400
Offline senter
« Reply #66 on: Thu, 22 June 2017, 08:36:23 »
Design it more like 3494 two side
Offline ppp
  • KappaKeepoKoopa
« Reply #67 on: Thu, 22 June 2017, 08:58:21 »
Another question, for the available colors, are those the colors for the case AND the orange weight? or just the case?
I'm like 99% sure I'm going to be going in on this.
Offline senter
« Reply #68 on: Thu, 22 June 2017, 09:40:07 »
Available for the case weight and nameplate also
 :thumb:
Offline senter
« Reply #69 on: Thu, 22 June 2017, 10:58:02 »
Yes.is made by microarc oxidation. :thumb:
Offline 19820815
« Reply #70 on: Thu, 22 June 2017, 20:24:05 »
Offline senter
« Reply #71 on: Thu, 22 June 2017, 21:59:25 »
Offline doom2
« Reply #72 on: Fri, 23 June 2017, 08:48:12 »
Can we see a render of the name plate?
Offline papa
« Reply #73 on: Fri, 23 June 2017, 12:11:45 »
I don't think so .maybe just make it look nice.
从我的 iPhone 发送,使用 Tapatalk
Offline senter
« Reply #74 on: Fri, 23 June 2017, 21:19:52 »
Name plate is another option not have a prototyper
Offline senter
« Reply #75 on: Sat, 24 June 2017, 09:31:59 »
You right.bro
Offline senter
Re: [IC] Fox-orange 80% Custom TKL UPDATED PICTURES !!!
« Reply #77 on: Wed, 28 June 2017, 00:45:58 »
Updated.
Offline Gajible
« Reply #78 on: Wed, 28 June 2017, 01:17:56 »
Looking good dude. I'll probably buy one, but it will really be colour dependent.
Offline duynguyenle
  • Personal text? What personal text???
« Reply #79 on: Wed, 28 June 2017, 07:00:53 »
Can you show a picture of the USB port cut out?
Also, will this keyboard be compatible with third party PCBs (for example Leeku A87 PCBs) or is the pcb specially designed for this keyboard?
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline senter
« Reply #80 on: Wed, 28 June 2017, 07:25:41 »
Special desgn .the usb is nondisjunction line
Offline senter
« Reply #81 on: Wed, 28 June 2017, 10:02:23 »
Yea it will have
Offline papa
« Reply #82 on: Wed, 28 June 2017, 12:50:53 »
Oh my god. I'm really can't wait anymore.
Offline senter
« Reply #83 on: Wed, 28 June 2017, 20:13:14 »
Thanks
Offline flyingalbatross1
« Reply #84 on: Thu, 29 June 2017, 08:07:18 »
Can it have ISO layout?
Offline senter
« Reply #85 on: Thu, 29 June 2017, 10:08:45 »
See the plate it have
« Reply #86 on: Thu, 29 June 2017, 11:02:32 »
Awesome. I'm new to this, i can see now.
So, if I were to acquire this, I would need to add switches (Cherry/Gateron) to the PCB you provide and then add Keycaps as well. This sounds like assembly is quite straighforward.
Offline KetchyKech
« Reply #87 on: Thu, 29 June 2017, 11:03:02 »
This is amazing ~ may be in for 2 at this point. Very unique!  :p
Offline duynguyenle
« Reply #88 on: Thu, 29 June 2017, 17:14:24 »
Don't forget stabilisers and a cable (assuming you already have soldering equipment)
Offline senter
« Reply #89 on: Thu, 29 June 2017, 21:24:58 »
Thanks :thumb:
Offline senter
« Reply #90 on: Thu, 29 June 2017, 21:28:37 »
Yea,u can try it :thumb:
Offline doom2
« Reply #91 on: Fri, 30 June 2017, 08:48:35 »
Almost GB time!
Offline Avalai
    • Instagram
« Reply #92 on: Fri, 30 June 2017, 09:13:28 »
Damn, if I hadn't just bought a TKL I would be seriously considering this. It's looking really nice, good luck with the GB!
