Author Topic: Leopold fc 660c usb mini connection issues?  (Read 1957 times)
Offline bern43
« on: Fri, 16 June 2017, 08:27:20 »
I've got a Leopold 660c on pre-order.  How common are the issues with the mini-USB connection on the board breaking?
That the connection is just soldered directly on the board without the feet going through isn't very reassuring, especially considering the cost of the board.
« Last Edit: Fri, 16 June 2017, 10:49:07 by bern43 »
Offline hking0036
Re: Leopold fc 660c usb mini connection issues?
« Reply #1 on: Fri, 16 June 2017, 09:23:17 »
I never had any issues with it, but you can buy a replacement controller from hasu (with more features) anyways so I wouldn't be too concerned about it, if it does break you just have to pop it open and swap, takes about 15 minutes, and only because the clips are weird to get open.
Realforce RF87UB 45g Uniform | Leopold FC660C w/ TMK | IBM Model M - 3/24/1997 | IBM Model F 122 - 11/25/1985 ANSI'd w/ TMK | IBM Model F XT in a box
