Author Topic: [IC] GMK Pristine (BoW Black on White, L9 runs first, WS1 soon^tm)  (Read 73313 times)
Offline duynguyenle
  • Personal text? What personal text???
Thanks for all your replies!
I apologize for not updating for quite a while :(
Getting an internship in a hospital recently and some school work earlier have kept me busy :(
Good news is that the renders for WS1 CP and L9 are ready! ;) I will upload them soon and start a google form
I still need suggestions on the keys included, are 143 keys too many? Are there any keys I could take out from this set?
And what packaging do you guys want? Plastic bags or case?
I suggest starting with the keys provided for the barebones stormtrooper keyset and then add the 7 keys required for 1800 support, that should then cover most popular layouts
| QFR            | Leeku 1800    | Raptor K1      | Dolch Pac
Offline ricyuyc
I would pick the L9.
Would you consider to add an addition bottom row in R5 profile, like that in Blue Alert(Olivetti)?
Offline DocMK
Windowed Caps and Scroll Lock? 👀
Offline ideus
  • Björkö.
You should add a full touch 1.75 R3 control to cover the HHKB, the step version of that cap is cool, but the full touch is preferred. Also, if you want to get the caps count down you can replace the UK specific keys for the R3 `~ and  \| keys to have those ANSI users that preferred an ISO enter covered.
Offline fishpod
Re: [IC] GMK BLACK on WHITE(07/14 Vote for your favorite white!!)
« Reply #54 on: Fri, 14 July 2017, 07:03:19 »
07/14
VOTE FOR YOUR FAVORITE WHITE!!
https://goo.gl/forms/De71cfdzTXOY8Beg1
Now we have 143 keys in total. Are there any keys that are redundant? Can some of them be removed? I want to hear from you guys ;)
Also, i will reveal the results of the poll for modifiers later. stay tuned!
thank you for all your support ;)
Offline fishpod
will change the stepped ctrl to a full touch ctrl ;)
« Last Edit: Fri, 14 July 2017, 07:44:29 by fishpod »
Offline avid
« Reply #56 on: Fri, 14 July 2017, 07:31:33 »
Will JTK ever do Iso enter? This is basically whats stopping me from buying it.
Offline fishpod
« Reply #57 on: Fri, 14 July 2017, 07:44:08 »
This is a GMK set ;)
Offline avid
« Reply #58 on: Fri, 14 July 2017, 08:01:14 »
Ops! Intended to post in the JTK black & white thread.
Offline neralo
« Reply #59 on: Sun, 16 July 2017, 20:07:47 »
07/14
Would it be possible to include a "00" key for those of use with numpads that have a split 0?
HHKB Pro 2 55g | TGR 910 55g Vintage Blacks | Apple Standard M0116 Orange Alps | Rosewill RK9000 Cherry MX Blues | Diverge TM 2 WKLears
Offline fishpod
Re: [IC] GMK BLACK on WHITE(GB ended / winners announced)
« Reply #60 on: Wed, 19 July 2017, 06:26:58 »
HERE I DID A BIG MISTAKE
THE HIDDEN CONTENT SHOULD GO TO MY JTK GB POST
SORRY FOR THE INCONVENIENCE
MY BAD :(((( was too hyped cause my first GB went well and being careless, sorry guys. THE GMK BLACK on WHITE GB has not started. It will be on soon!
GB ended
thank you for all your support.
we sold a total of 149 sets with 120 orders. 58 international orders and 62 from China
How were the winners generated?
1. Got a list of orders from zFrontier and made an copy.
2. Censored LAST NAMES of most of the buyers for privacy concerns. (Most because some of them are obvious pseudonyms and some of them i am not sure if i censored the last name or the first name :( sorry if i couldnt figure it out)
3. Generated a random sequence and sorted the list with the sequence generated
4. Generated random 3 sets of 10 random numbers from 1 - 120. Each set has 1 winner.
5. Generated 3 random numbers from 1 - 10. Each number decides which number will be counted to in number set, and that is the winner.
RESULTS HERE
173684-0
Congrats! The orange on white will be shipped with your JTK White on Black order:)
the EXCEL FILE i used to generate the winners could be viewed here
https://drive.google.com/file/d/0B7jz8bTIQ0yvR3pBTFNSakhlMUU/view?usp=sharing
screenshots from the random number generator:
http://imgur.com/a/XlK2b
thank you for all your support!
and please also support me on my
GMK Black on White project
https://geekhack.org/index.php?topic=90220.0
<3
« Last Edit: Wed, 19 July 2017, 08:57:35 by fishpod »
Offline ctrlX
« Reply #61 on: Wed, 19 July 2017, 06:43:18 »
Eh...? When did this even go from IC to GB? Says in thread title [IC]. Confused...
Sent from my Nexus 5X using Tapatalk
Offline fishpod
« Reply #62 on: Wed, 19 July 2017, 08:44:49 »
am confused too. Maybe I should've said GB CLOSED instead of GB ENDED :( my bad.
I modified in the wrong post
« Last Edit: Wed, 19 July 2017, 08:58:56 by fishpod »
Offline ideus
  • Björkö.
« Reply #63 on: Wed, 19 July 2017, 08:45:27 »
@fishpot:
The communication on the IC-GB was not clear here at GH, it was never stated what was the final layout of the set, not any final details. I suggest you to review the case and get some lessons learnt. The bad part is how easy is for people to loss creditability for things like this.
Offline fishpod
« Reply #64 on: Wed, 19 July 2017, 08:49:32 »
@fishpot:
Damn I modified the wrong post lol. I should've modified my JTK GB post but instead I did this.
What a big mistake!
Sorry for the inconvenience:( will change it as soon as I get home
Offline ctrlX
« Reply #65 on: Wed, 19 July 2017, 08:50:02 »
Still need more clarification.. Is the GB for GMK Black on White over or was that for the JTK Black on White set?
No link for actually purchasing the GMK set was posted so how can it be closed/ended?
Edit: ah I see now. No worries. Would be a good idea to edit the OP to avoid confusion. Cheers! :-)
« Last Edit: Wed, 19 July 2017, 08:51:39 by ctrlX »
Offline fishpod
« Reply #66 on: Wed, 19 July 2017, 08:54:31 »
AHHHHHHHH WHAT A BIG MISTAKE I HAVE DONE
AM REALLY SORRY :((((
I SHOULD HAVE MODIFIED MY JTK GB POST
again, My apologies
Offline fishpod
« Reply #67 on: Wed, 19 July 2017, 09:12:33 »
 i did the same mistake  :( :(
Offline ideus
  • Björkö.
« Reply #68 on: Wed, 19 July 2017, 10:12:42 »
OK, so this thread is still alive as an IC assessment.
Offline fishpod
« Reply #69 on: Wed, 19 July 2017, 10:33:23 »
Yes this is still an IC thread.
that mistake belongs to here https://geekhack.org/index.php?topic=90108.0
Offline ideus
  • Björkö.
« Reply #70 on: Wed, 19 July 2017, 14:22:56 »
Good news, I have high hopes on this, mostly, if it is finally made using L9 as the base color because it will be compatible with OG Cherry sets as well as with GMK beige replicas, besides that color matches great with other modern GMK mod sets.
Keep the good work.
Offline amnesia0287
  • Formerly Amnesia
« Reply #71 on: Wed, 19 July 2017, 20:41:05 »
Keep the good work.
If you want beige though, why not just buy this: https://detail.tmall.com/item.htm?spm=a230r.1.14.1.ebb2eb2hG1O1D&id=538159760577&cm_id=140105335569ed55e27b&abbucket=20&sku_properties=5919063:6536025
I would be sad if it's L9 as it's the only one I wouldn't buy. I want WHITE not OFFWHITE. But obviously if that happens then it is more popular so I totally understand... L9 just isn't for me. Same reason I can't bring myself to order Blue Alert despite the price still being pretty decent.
Offline ideus
  • Björkö.
« Reply #72 on: Wed, 19 July 2017, 21:56:53 »
Keep the good work.
That set is insanely expensive, besides, I already have some OG Cherry sets like it; in contrast, this one would feature the almost imposible to source L9 modifiers that are not available anywhere else; but, in some old keyboards that are very rare and have mod keys that do not fit modern keyboard layouts. Actually if this goes L9 its mods would be very valuable for weird OG aficionados like me.
A fellow GHer offered me the set in this keyboard; but, as you can see its mods are unusable on a modern layout. Anyway, the community will speak its preference; again, I am hoping to get a grip on one unique set in hundreds set, that would be the holy grail of the OG Beige sets. LOL.
Offline amnesia0287
  • Formerly Amnesia
« Reply #73 on: Wed, 19 July 2017, 22:05:42 »
That's totally fair, I always forget there is still a big subset of the keyboard community that's all about the retro/vintage stuff. It makes more sense in that context. I just like monochromatic w/color accent schemes and  to my brain beige isn't white or a shade of grey. But I wouldn't be salty if it went the other way, my wallet would be grateful (I'm already gonna go broke on laser anyway) and eventually someone will do B on WS1/2.
Good luck to both of us (but mostly me)  :p
Offline ba7777
« Reply #74 on: Wed, 19 July 2017, 22:07:25 »
L9 mod could provide much more compatibility for GMK beige set like retro/9009 and lots of OG beige set than ws1/cp mod.
Also IMHO L9 is more muted and goes nice with most white keyboards, at least IMHO.
Offline ImpendingxDoom
  • MF the SuperVillain
« Reply #75 on: Wed, 19 July 2017, 22:10:03 »
This is GMK Cyrillic without the Cyrillic. Its one of my favorite cap sets :D
Offline ba7777
« Reply #76 on: Wed, 19 July 2017, 22:12:06 »
The color code for gmk Cyrillic should be T9 IIRC, and it's more like very light grey.
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #77 on: Wed, 19 July 2017, 23:05:26 »
Exactly.  L9 will go the best with some of the mods being made for these more colorful GMK sets.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline ricyuyc
« Reply #78 on: Wed, 19 July 2017, 23:42:56 »
I would love to make it in L9 base, it could widely match with many other GMK mods. As mentioned before, it would be great if OP add R5 bottom row into
Offline ideus
  • Björkö.
« Reply #79 on: Wed, 19 July 2017, 23:51:03 »
+1, just imagine A profile bottom row in L9, it would be a keyboard nirvana, so unique and special and a dream come true. I have been looking for keys like these for years.
Offline tunadesu
« Reply #80 on: Sat, 22 July 2017, 19:00:23 »
I will cry forever if this becomes an L9 base  :'(
Offline ideus
  • Björkö.
« Reply #81 on: Sat, 22 July 2017, 20:30:19 »
Keep your tissues handy. LOL.
Offline fishpod
« Reply #82 on: Sat, 22 July 2017, 22:04:19 »
I am waiting for the final results from the poll i did in China, and hopefully we will narrow it down to 2 options and again we will start one more poll and we may probably see this happen in august ;)
Offline Kafka
  • i like clean things
« Reply #83 on: Sun, 23 July 2017, 20:37:05 »
I'm fine with L9, but I'd rather the mods be either icon only or text only. Normal mods would make this set even less unique imo.
Offline ideus
  • Björkö.
« Reply #84 on: Sun, 23 July 2017, 22:44:17 »
A full version of the Yuri's Icon Set is available for any upcoming GMK set, according with T0mb3ry's comment. Just imaging a set with those icons in these classic colors.
Offline Kafka
« Reply #85 on: Sun, 23 July 2017, 23:09:35 »
This would be awesome, it'd make the set a lot more desirable with the new legends.
Offline ideus
  • Björkö.
« Reply #86 on: Mon, 24 July 2017, 00:01:29 »
It'd be unique and the first set to use the icons for a full size keyboard.
Offline RevoTeam
« Reply #87 on: Mon, 24 July 2017, 02:12:44 »
CP or ws1. Personally i wanna ws1. But CP is more classic...Hard to chose between these two
Offline dfrib
« Reply #88 on: Tue, 25 July 2017, 06:59:04 »
Very interested  :thumb: I would probably prefer L9, but all three works for me; still missing a GMK BoW set.
2x Hypersphered Novatouch TKL, Filco Majestouch 2 TKL (Browns)
Offline fishpod
Re: [IC] GMK BLACK on WHITE (Poll results revealed! 07/30)
« Reply #89 on: Sun, 30 July 2017, 08:34:38 »
 ;) ;) Some updates! hope you like it
Offline KaosJ
« Reply #90 on: Sun, 30 July 2017, 08:51:12 »
What will be the price?
Offline fishpod
« Reply #91 on: Sun, 30 July 2017, 08:54:34 »
Once the color / layout are all finalized, I will update with the pricing
Offline duynguyenle
« Reply #92 on: Sun, 30 July 2017, 10:32:00 »
After seeing the renders, my suspicions are confirmed. WS1 is too bright. CP/L9 is the way to go. Unfortunately, it seems the polls do not support my opinion
Offline KaosJ
« Reply #93 on: Sun, 30 July 2017, 11:07:51 »
I have the samples, i would say WS1 is a white, CP is a creamy white, L9 is a nonononono (not a white at all)
WS1 or WS2 is the way to go if you want a nice white (like in this case). WS2 is the best white imho, surely better than WS1.
I would say WS2>WS1>CP
Offline fishpod
« Reply #94 on: Sun, 30 July 2017, 11:35:57 »
I personally prefer CP and L9 over WS1 for WS1 is to bright ;)
WS1 will be a great stand-alone BOW set, but perhaps will bring a sharp contrast (perhaps too sharp) when you pair it will other mods.
However, I think CP or L9 will not only be great being a stand-alone BOW set. CP and L9 are more mild and soft, they will match very well with many mods in different colors, especially L9
we will see how this will finally go. ;)
Offline TalkingTree
    • My projects
« Reply #95 on: Sun, 30 July 2017, 12:49:36 »
B: we go vintage AF - L9 with icon+text mods with R0 and R5
You got my attention.
Offline duynguyenle
« Reply #96 on: Sun, 30 July 2017, 16:29:39 »
Exactly what I wanted to hear :)
Offline ullr
« Reply #97 on: Tue, 01 August 2017, 23:58:58 »
Not pleased with the decision to narrow it down to exclusive combinations of colors and features, honestly. I would prefer WS1 or CP but would absolutely be fine with L9 (especially with R5 mods sweetening the deal) — but icon mods or bust.
Offline basically_i_suck
« Reply #98 on: Wed, 02 August 2017, 06:35:13 »
I'm happy with the 'Modern Classic' vision with the icon only modifiers and either of the lighter whites.
Anxious to see what the final result will eventually be.  :thumb:
Offline crtexcnndrm99
  • *profile image used without permission* ;)
« Reply #99 on: Wed, 02 August 2017, 06:37:32 »
Yup this is where it's at.
You're a smooth smoothie, you know? ~ Gaear Grimsrud
