Author Topic: Restore FN key to HHKB Hasu Bluetooth  (Read 1837 times)
Offline JunkFace
« on: Tue, 27 June 2017, 08:56:58 »
I was just wondering if I could restore the function (FN) key to the HHKB after a Hasu Bluetooth controller has been installed.  I don't see any place to set this up in the firmware, only keys to change the layers.  I've gotten so used to the HHKB's layout not having the FN key is a real pain.  I'd be fine with the layers if it worked like a switch but if its going to change the whole keyboard layout that won't do for multi-key commands like ctrl+alt+del or alt+printscreen, ctrl+f5 etc.  Anyone have any insight on this?  I'd really like to avoid remapping several layers, making new macros or doing any kind of software level keybindings.
Please let me know!
Offline Tactile
Re: Restore FN key to HHKB Hasu Bluetooth
« Reply #1 on: Tue, 27 June 2017, 09:29:55 »
You'll probably have better luck if you ask here.
REΛLFORCE
