Author Topic: Filco Numberpads  (Read 61733 times)
Filco Numberpads
« on: Wed, 28 June 2017, 11:01:24 »
Do the filco number pads that just came into stock send actual number pad codes?
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Moderator
  • The 00verseer of Vault 77
    • Mechanical Keyboards
Re: Filco Numberpads
« Reply #1 on: Fri, 30 June 2017, 10:04:39 »
I will check one out today and get back to you.
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline 00zeRO
  • * Moderator
« Reply #2 on: Fri, 30 June 2017, 16:17:12 »
Confirmed!:
« Reply #3 on: Fri, 30 June 2017, 17:27:43 »
 Awesome,  thanks.
