Author Topic: DOLCH PAC-6x sniffers and Cherry blues?  (Read 45127 times)
Offline Nonmouse
« Reply #50 on: Thu, 13 May 2010, 10:32:59 »
Quote from: itlnstln;181874
I ran XP on my abacus... *****es.
Actually this is theoretically possible- but you'd have to add a lot of extra memory, and boot time would be pretty laggy...
Offline ch_123
« Reply #51 on: Fri, 14 May 2010, 18:45:38 »
I now have two Dolch PACs (with Blue Cherry keyboards) on the way to me.
« Last Edit: Fri, 14 May 2010, 19:17:38 by ch_123 »
Offline elbowglue
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline J888www
« Reply #53 on: Sat, 22 May 2010, 09:12:40 »
Quote from: elbowglue;185568
Here's another one on ebay:
http://cgi.ebay.com/Dolch-PAC-63C-Network-General-Sniffer-/290435771305?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item439f522ba9
This unit have issues which may/may not be repaired, but the good thing is that the seller confirmed he is willing to ship only the KBD, else shipping cost will be quite hefty.
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline ch_123
« Reply #54 on: Sat, 22 May 2010, 09:14:32 »
Quote from: J888www;185694
The unit powers up and shows a "non-system disk error"
In other words, the "The seller is an idiot" error.
Offline ch_123
« Reply #55 on: Sat, 22 May 2010, 12:03:05 »
The sad thing is that there are people who want the whole deal who are in risk of having the keyboards poached off them. This is different to other keyboards because the keyboard is an intrinsic part of the Dolch (it doubles as the screen's cover) and thus buying a Dolch without the keyboard is sort of like buying a laptop with the keypad and touchpad ripped out.
Offline Nonmouse
« Reply #56 on: Sat, 22 May 2010, 12:20:21 »
They use a standard form factor motherboard, don't they?  Seems like it should be (relatively) easy to upgrade them to a modern system...
Offline didjamatic
« Reply #57 on: Sat, 22 May 2010, 19:49:49 »
I bought a Dolche board from Ricercar and LOVE IT.  This is what Cherry Blues should feel like. It's been my main driver at home since I got it from him.
Offline ricercar
  • mostly abides
« Reply #58 on: Sat, 22 May 2010, 20:37:18 »
I got a HeadStart Cherry blue board, and the switches all need cleaning before they will click.
Offline didjamatic
« Reply #59 on: Sat, 22 May 2010, 22:49:00 »
Ricercar, your avatars keep getting better and better.  Bummer about that HeadStart.
Offline ricercar
  • mostly abides
« Reply #60 on: Sun, 23 May 2010, 15:06:09 »
Quote from: didjamatic;185902
Thanks.
I'm not giving up on the HeadStart. I could get all pissy or I can fix it. Or both. Fixing it without wondering 'what if' seems like the funnest path.
« Reply #61 on: Fri, 25 June 2010, 07:05:47 »
I (finally) made a cable to connect my Dolch keyboard with 4P4C ("RJ") connector to PS/2 and I'm typing away at it now. The cable is connected to the PCB inside the case with a connector, so you don't have to solder anything, just replace the cable. However, I did have to widen the hole to fit my new cable. The 4P4C pin order is: GND, +5V, data, clock.
Offline ch_123
« Reply #62 on: Sat, 26 June 2010, 05:52:17 »
From left to right or what?
« Reply #63 on: Sat, 26 June 2010, 08:18:32 »
Quote from: ch_123;196625
According to the standard convention for numbering pins on xPxC/RJ-connectors. Allow me to quote a good explanation on Wikipedia:
Holding the connector in your hand tab side down with the cable opening toward you, the pins are numbered [1-4], left to right.[...]
BTW, when you reassemble the case, be mindful that there are two sizes of case screws. The short ones go in the front and the long ones go in the back. If you use a long one in the front, it might penetrate to far and you will get a plastic nub below the keys ...
« Last Edit: Sat, 26 June 2010, 08:28:48 by Findecanor »
Offline ch_123
« Reply #64 on: Sat, 26 June 2010, 08:20:51 »
Cool. Now I'll be able to make a PS/2 adapter for my keyboards.
Offline Oqsy
« Reply #65 on: Thu, 12 August 2010, 01:01:51 »
I got my dolch PAC 60 today and it seems great except a "hard drive controller failed" message on boot. Boots to floppy fine, and the hard drive specs are still in CMOS. Not sure how to proceed, but it does seem possible someone opened it up, poked around to see what parts might be stripped from it, decided it wasn't worth the trouble, and reconnected the IDE cable from the HDD to the controller backwards since the older connectors allow that.
The only problem is that I don't know which orientation is "correct" without a tab, etc. I haven't had to swap one from this era to my knowlege, or if I did I got lucky and always put them back correctly. ;).  Please advise.
I've also been considering rebuilding it with an atom or similar mb, a nice little rig to be my equivalent if a laptop (ac power required, however unless I delve into laptop psu and batteries which doesn't really seem worth it to me).
Maybe make a cutout for a DVD-Rom, add big HD, a wireless NIC and go to town. ;)
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline Oqsy
« Reply #66 on: Sun, 15 August 2010, 17:15:47 »
Quote from: Findecanor;196218
Ok, I'm wanting to make a cable with female rj-11 to male ps/2 (6-pin mini din to you dorks) so that I can plug the dolch keyboard into other systems with ps/2 ports, but not change the cable out at all so that it's still in factory condition and will work in conjunction with the PAC 60 without even opening the case and changing cables.
I have a pile of PS/2 extensions, and an old 4 prong to RJ-11 female adapter housing.
<- don't use these, the jack is not compatible with Dolch's RJ-11 connector.
I realize my adapter + cable might be UGLY, but it should work perfectly electronically, and has the advantage of being able to click the rj-11 male directly into a real jack.
I know that this should be relatively simple, but my brain starts to hurt when I try to map this stuff out in my head, so I wanted someone here that understands findecanor's pinout to explain which pins need to connect to which at each stage of my plan to make it work...
I've got a multimeter and can test continuity (I have already numbered the prongs on the adapter box 1-4)
« Last Edit: Sun, 15 August 2010, 23:17:05 by Oqsy »
Offline Oqsy
« Reply #67 on: Sun, 15 August 2010, 19:00:01 »
Nevermind, I'm pretty sure I got it.  I got lucky and when I opened up that little adapter box, the RJ-11 leads ran to screw posts which corresponded with the prongs.  There was a blank for another hole in the back of the housing, so I drilled it out, and ran my leads from the PS/2 extension into the housing.  Screwed the corresponding ps/2 lead to the post with the RJ-11 leads.  Black-taped around the entire housing except the RJ-11 jack, and it's all ready to go!  Time to reboot and test this mutha out.
Offline Oqsy
« Reply #68 on: Sun, 15 August 2010, 20:33:47 »
Findecanor, you mf-er...  were you going left to right on the male plug, or the female jack???  I'm almost positive my stuff is all inverted.  Continuity checks out as per the diagrams I posted above (with the RJ-11 MALE PLUG labeled 1-4 left to right.)  If you gave the pinout of the FEMALE JACK then I'm screwed, but I'm not rewiring it until I'm sure which is correct.
Offline Oqsy
« Reply #69 on: Sun, 15 August 2010, 23:12:53 »
This is what I take from consultation with dfj, kishy, and multiple readings of findecanor's post.  Anyone with other interpretations, please let me know before I kill my ps/2 bus or my keyboard :D
Edit: By the way, stay away from that adapter I posted above.  It has 4 pins, but the female jack is too large for the RJ-11 that comes on the Dolch.  It just wiggles around with no contact, so I tossed it.
« Last Edit: Sun, 15 August 2010, 23:16:19 by Oqsy »
« Reply #70 on: Mon, 16 August 2010, 08:17:24 »
Quote from: Oqsy;212961
I have a healthy sex life. How about you?
Because I modified a cable, I put a new male plug on it:
pin 1: GND,
pin 2: +5V
pin 3: data
pin 4: clock
(Picture copied from Wikipedia)
« Last Edit: Mon, 16 August 2010, 09:03:17 by Findecanor »
Offline Oqsy
« Reply #71 on: Mon, 16 August 2010, 12:18:56 »
Thanks findecanor, that answers everything. Oh and for everyone's general knowledge, these connectors are RJ-22, *not* RJ-11.  RJ-22 is the 4 pin "handset" cable connector. A lot of phones with the coiled handset cables use RJ-22, but some use RJ-11. The two are not physically compatible, so use caution.
Offline Oqsy
« Reply #72 on: Mon, 16 August 2010, 19:47:24 »
This seems to confirm my diagram, even though the plug pictured is from "behind", the pin outs seem copacetic.  Re-splicing!
Offline didjamatic
« Reply #73 on: Mon, 16 August 2010, 21:37:40 »
Great contributions guys.  Dolch boards kick friggin butt, the right Ctrl+Alt being close together on these types of G80-1800 layouts let you use your thumb to do Ctrl+Alt in 1 press, and middle finger hits del just right.  This was an issue I had early on with 1800 layouts because I couldn't 1 hand ctrl+alt+del but then I realized with the non-win-key models like the Dolch boards, you can do it even easier.  Ctrl+alt+ins is just as easy.
Offline Oqsy
« Reply #74 on: Mon, 16 August 2010, 21:50:58 »
Yep, mine is now up and running!  I'm typing on it now.  It's a really nice feeling board.  I love the layout, the colors, the switches, the double shot key caps, and even the scooped F and J.  This is one of my finer moments in vintage gear hoarding ;)
Offline Oqsy
« Reply #75 on: Sun, 22 August 2010, 01:22:22 »
Removed everything but LCD and mainboard to see how impossible a rebuild would be. The board is 21cm x 33cm. I have no idea if it's a standard if any kind. I'm mostly worried about connecting the LCD and making sure psu and exp cards will line up correctly. Any suggestions?
Edit: According to the chart at http://en.m.wikipedia.org/wiki/Computer_form_factor?wasRedirected=true it's a baby-at board. That probably won't help me find a suitable replacement, but it's nice to know.
Offline Half-Saint
« Reply #76 on: Mon, 23 August 2010, 01:35:42 »
You could modify the case and just throw a mini-ITX board in there?
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline Oqsy
« Reply #77 on: Tue, 24 August 2010, 18:40:49 »
half-saint: i *could*, but preserving as much of the original case is part of the goal.  kishy and I have been brainstorming on this for a few days, and all solutions have their drawbacks.
One thing to note is that the LCD runs off of an ISA graphics card that *most likely* has a lot of the LCD functionality built into the card instead of the LCD assembly itself (like most modern LCDs)  This means that to keep the LCD currently installed in the mix, I'd have to either:
1. find a suitable card for keeping it running (one small and one large ribbon cable carrying the signals) that would work on a newer form factor motherboard that would fit the case.
2. keep the ISA card and find a motherboard that will accept the ISA gfx card
3. abandon the existing LCD, and drop an extra $200 or more on a replacement for one that already works perfectly just to get around the ISA card.
There have been lots of theories and suggestions tossed around (join us on #geekhack at chat.freenode.net on your irc client, or just click the link in the very top right of this page for the webchat), and I haven't committed totally to any of them.
I will most likely start a new thread on this topic to get more input as I feel like there may be some other answers out there that I haven't considered.
« Last Edit: Tue, 24 August 2010, 22:37:21 by Oqsy »
Offline Oqsy
« Reply #78 on: Tue, 24 August 2010, 22:41:37 »
I found this:  http://www.ibasetechnology.net/mb894.html which looks promising...  I would have to do some creative cable routing / exp. slot blank drilling to make the i/o stuff work out.  That or drill out some sections of the case for them which was against the plan to begin with.
Anyway, I'm sure the idea of modernizing this box won't come back to bite me in the AAAAAAAAAAAAHHHH!!!
edit: nevermind, silly mistake, the board above is 24.4x24.4cm, and the smaller dimension of this case is 21.9cm.  Dagnabit.
« Last Edit: Wed, 25 August 2010, 00:32:08 by Oqsy »
Offline Oqsy
« Reply #79 on: Wed, 25 August 2010, 17:57:04 »
To keep this thread from derailing into my personal build thread, I've started a new one here specific to the issues of rebuilding the DOLCH PAC 60 as a portable modern pc.  Direct all replies to that discussion there please, so this discussion can revert back to the keyboard that comes with the DOLCH PAC sniffers and the cherry blue goodness inside :D
Offline gosper
« Reply #80 on: Wed, 08 September 2010, 17:13:35 »
A little off topic here but has anyone been able to get any flavors of linux to boot on any DOLCH PAC models?
Offline ch_123
« Reply #81 on: Wed, 08 September 2010, 17:27:49 »
I haven't tried it yet. Bear in mind that the screen is controlled by a custom PCI card. That said, Windows 2000 picked it up out of the box when I installed it, so the chipset could be common enough.
Offline ricercar
  • mostly abides
« Reply #82 on: Sat, 30 October 2010, 00:03:39 »
Anyone have a RJ45 (Ethernet) pinout for a Dolch with trackpad?
Offline ricercar
  • mostly abides
« Reply #83 on: Thu, 31 March 2011, 17:49:32 »
made a cable... pin order is: GND, +5V, data, clock.
Works for me, too
Wired an "Airlink" Dolch clone Cherry blue keyboard RJ11 to PS2. The wire colors were counter-intuitive.
+5 = Black
GND = White
Data = Yellow
Clock = Red
« Last Edit: Thu, 31 March 2011, 18:07:24 by ricercar »
Offline wanabe
« Reply #84 on: Thu, 31 March 2011, 17:56:25 »
I need to do this.  are you guys clipping the connector and soldering a ps2 connector, or making some sort of adapter to maintain the original rj connector
Offline ricercar
  • mostly abides
« Reply #85 on: Thu, 31 March 2011, 18:10:30 »
I removed the RJ11 wiring entirely, and soldered an old model M cable to the 'dolch' PCB.
Offline Oqsy
« Reply #86 on: Thu, 31 March 2011, 23:54:29 »
I made a new, second cable for mine.  I kept the original cable for use with the dolch unit, and wired up another one to a hacked up extension ps/2 cable with simple splices.  The keyboard had a female jack for the rj connector inside the case, so swapping cables is quick and easy.
Offline wanabe
« Reply #87 on: Fri, 01 April 2011, 00:22:57 »
interesting...i wish i could check it out, but i cant figure out how to crack it open.  can anyone explain how to open a dolch keyboard?
Offline wanabe
« Reply #88 on: Fri, 01 April 2011, 12:12:56 »
sweet - thanks!
Offline ricercar
  • mostly abides
« Reply #89 on: Fri, 01 April 2011, 22:21:48 »
Kishy, you're Super Awesome Man, earning a gold star for the day. Your colors are now proven accurate/successful on a third Dolch keyboard with trackpad.
Offline hasu
  • @tmk
« Reply #90 on: Wed, 22 February 2012, 19:45:24 »
Kishy, Thanks for the great info.
I could make my adapter for PAC 64 due to your nice pic of pinouts.
