Author Topic: [IC] GMK Eclipse  (Read 87693 times)
Offline T0mb3ry
  • https://www.instagram.com/t0mb3ry_gh/
    • Flickr
Re: [IC] GMK Eclipse
« Reply #250 on: Fri, 06 October 2017, 18:48:05 »
Well here we go :)
Order placed!
:thumb:
Nice to see the GB is up! Good luck  :thumb:
Is it possible to include all the color codes?
Thanks,
What do you mean by including all color codes? I assume you mean showing the color codes in mockups?
Yep, showing the color codes. Always difficult to tell colors from renders alone.
Just updated all kits with colorcodes and added also row info to NORDE kit. Keep in mind custom colors do have hex values instead of GMK color codes.
Hope these infos are helpful :)
Standard Base kit
Accent kit
NORDE kit
Offline avid
« Reply #251 on: Fri, 06 October 2017, 18:50:09 »
Thanks for the update! Very helpful.
Offline bkw1209
« Reply #252 on: Sat, 07 October 2017, 00:34:23 »
very expensive....
« Reply #253 on: Sat, 07 October 2017, 00:40:43 »
very expensive....
Standard GMK price
Offline CandyKeys
  • Just doing EU things.
    • CandyKeys EU MK Store
« Reply #254 on: Sat, 07 October 2017, 02:21:14 »
very expensive....
Actually quite well priced for the amount of keycaps...
The CandyKeys Mechanical Keyboard Store
Offline HotRoderX
« Reply #255 on: Sat, 07 October 2017, 02:29:20 »
digging this set special with that white set of modifiers.. perhaps those are violet blue? I am not sure but they look really amazing and the fact there so unique makes them stunning.
Offline T0mb3ry
    • Flickr
« Reply #256 on: Sat, 07 October 2017, 02:41:21 »
I assume you mean the light blue modifiers from accen keys. Violetblue is the basecolor of modifiers accordingly to RAL color palette.
Maybe you are looking at the picture from your mobile device and it does not display the colors properly.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #257 on: Sat, 07 October 2017, 02:42:37 »
GB Thread is live.  Please continue discussion there:
GMK Eclipse
https://geekhack.org/index.php?topic=91931.0
GLWGB! :thumb:
