Author Topic: LEDs - Any good way to view and compare them without adding them to a switch?  (Read 6627 times)
Offline pon10
  • looking at my keycaps..
Hey good people
I have a bunch of LEDs i bought random places for some upcoming builds, I am still a little new to DIY electronics
Just need a good advice how to "manage" your LEDs and view them turned ON, easy without putting them in a switch for testing colors and compare brightness etc.
Any good, lets say Usb tool out there?  :-*
just something that have resisters already and less time "source" consuming - pre built little usb power thingy :)
I need to get stuff sorted :p
172302-1
« Last Edit: Mon, 03 July 2017, 17:12:13 by pon10 »
Offline Tactile
You could just get an LED tester like this.
REΛLFORCE
Offline pon10
Awesome thank you! i have been inputting that exact keyword but no luck  :-X
Edit: Got this little fella
« Last Edit: Tue, 04 July 2017, 04:35:33 by pon10 »
FWIW I have a breadboard like you illustrated, but it has a power board plugged into one end.  I just use that with a resistor.  Simple and effective.
Offline pon10
Cool!, i wanted todo that but it has been 15+ years since school i am just starting to get into diy hoppy electronics and learning again :) but since this is the way to go and more fun in what i ordered above :)
i would be able maybe to build one with something like THIS power supply module right? and just use the power from the usb? instead of 12v
Yep - pretty much exactly that one.
I do not have a suitable USB cable to power it, but I do have an old wall wart that happens to work well.
You can also change a couple of jumpers on it to switch from 3.3V to 5V.  I have mine on 5V.
Offline pon10
Cool! i want to make one, but time :)
Here if anybody stumble upon on this thread i got this very very cheap thinghy, it works quick and have clicky switches :)
173618-0173622-1
