Author Topic: Noob alert - how do I put enter and backspace keycap  (Read 5898 times)
Offline dragonload
« on: Thu, 06 July 2017, 08:40:03 »
Hello, im upgrading a noppoo choc mini with o-rings and I actually don't know how to put those 2 keys in. I don't wanna break it. Just press the keycap down and thats it?
http://imgur.com/a/VEWSY
Offline clasicks
  • Formerly KeyboardUser4
Re: Noob alert - how do I put enter and backspace keycap
« Reply #1 on: Thu, 06 July 2017, 08:43:48 »
You should have some Costar Inserts that go into your keycaps that attach to the stabilizer wire - they are little white "loops"
http://imgur.com/gJCOe4T
Offline zeltner
« Reply #2 on: Thu, 06 July 2017, 08:48:29 »
Picture is blurry but it looks like there are black inserts in the keycap already? The ends of the wire need to go into these inserts. Easiest way is to take the adjacent keycaps off to give yourself a little space to work. Slide one end into the wire then tilt it to get the other end in. then press the cap onto the switch stem.
Offline clasicks
« Reply #3 on: Thu, 06 July 2017, 08:49:35 »
DOH! didnt even see them, ignore my post OP, you already have your inserts!
Offline Elth
« Reply #4 on: Thu, 06 July 2017, 08:50:23 »
The inserts are there, they're just black and not white in color.
Here's a video dragonload:
Offline dragonload
« Reply #5 on: Thu, 06 July 2017, 09:31:14 »
I got it. Thank you!
Offline Hyde
  • White Tofu Extraordinaire
« Reply #6 on: Fri, 07 July 2017, 10:44:29 »
This is a better approach, I always do it this way.  :)
