Author Topic: Custom KBD75 R1 Plate Modifications  (Read 1817 times)
Offline CAPS UNLOCKED
    • capsunlocked
« on: Fri, 07 July 2017, 01:03:03 »
Hey,
I have a KBD75 R1 DIY kit, that I am yet to assemble.
I am thinking about getting a custom Brass plate cut, to replace the stock plate, but was curious as to what modifications I should make to the stock plate design to overcome any plate issues.
Does anyone know exactly what the measurements are of the modifications I need to make to remove any issues with the stabilisers and the plate? Does anyone have any drawings of the new plate?
Thank you.
