Author Topic: Our options for Filco Zero keycap sets (Alps)  (Read 3009 times)
Offline directheatedtriode
« on: Sat, 08 July 2017, 19:47:23 »
I've done  several searches and figured I would create this thread- I'm wondering what is currently out there for the Filco Zero, as I understand from this thread it uses Cherry stabilizers just on the space bar but not on other keys :confused: What a weird setup. I would ideally like to get black keycaps just like the stock Zero.
Currently available that I know of:
Tai Hao double shot ABS- mechanicalkeyboards.com, Massdrop
"Vintage" (are they new old stock they found?) ABS keycaps - mechanicalkeyboards.com - unsure if they sell these separate from the KBP V80
Are there any vintage Alps boards that wouldn't cost a fortune that would be able to serve as a complete donor? I am guessing the answer is a resounding no. I see that SGI Granite (some Dell AT101W) can serve as partial donors, but then you're left with mismatches with the Filco stock caps.
Unknown ETA:
Matias PBT- they have been saying for a year or two that they'd be coming.
Re: Our options for Filco Zero keycap sets (Alps)
« Reply #1 on: Thu, 13 July 2017, 10:04:24 »
Bump.
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #2 on: Thu, 13 July 2017, 10:20:33 »
you can bend different stab wires for the stabilized keys and use a set made by SP that way (alps mount with mx stabilizer inserts)
