Author Topic: JD40 Newbie  (Read 2090 times)
Offline ceed
JD40 Newbie
« on: Sun, 23 July 2017, 05:59:32 »
Hey guys,
I just bought a jd40 pbc from 1up.
I have basically no experience with custom keyboards.
But shouldn't connect to my mac by default?
I Just connected the blank pbc to my macbook and exactly nothing happened.
I also looked around for manuals, but it seemed like it should be plug and play by default.
Am i missing something here?
Thx in advance.
Offline ceed
Re: JD40 Newbie
« Reply #1 on: Fri, 04 August 2017, 11:51:57 »
Okay, figured it out, i wanted to flash the board, but parralles always disconnected the keyboard from my mac on the reboot.
Annoying as **** ^^
Offline xtianyves
    • YvesDrop
Re: JD40 Newbie
« Reply #2 on: Fri, 04 August 2017, 12:05:21 »
Are you trying to flash it within Parallels or mac OS?
Offline novelty
Re: JD40 Newbie
« Reply #3 on: Sun, 06 August 2017, 18:26:58 »
I used VMWare, mounts the pcb without a problem. You want to follow this guide
