Author Topic: Plate Mount Cherry Stab Hole Question  (Read 4572 times)
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« on: Wed, 26 July 2017, 04:03:32 »
Is it true that plate mount Cherry stabs will fit into holes designed for Costar ones? Also are they like PCB mount ones where you have to desolder the entire keyboard to fix the stab?
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline TalkingTree
    • My projects
Re: Plate Mount Cherry Stab Hole Question
« Reply #1 on: Wed, 26 July 2017, 04:33:24 »
No, the plate cut outs for Cherry's and Costar's stabilizers are completely different. Although a combined cutout can be easily achieved by overlapping the two;
 swill's builder will graciously do the dirty work for you.
Not for 2u keys, it highly depends on the cutout for larger stabilizer. The wire will go underneath the plate, so make sure you have the longitudinal cutout across the switch hole, between the two stabilizers' cutout for this very purpose. Again, swill's tool is already programmed to do so.
Offline _haru
« Reply #2 on: Wed, 26 July 2017, 04:40:22 »
Got it.
Can we remove/fix teh stab with Costar ones?
Offline TalkingTree
    • My projects
« Reply #3 on: Wed, 26 July 2017, 04:48:20 »
Absolutely. In Costar stabilizers, the wire sits on the top of the plate, as you can see here.
The only catch is with the switch orientation: Costars' wires must be placed on the LED side of the switch. Keep that in mind when placing the ISO Enter switch, if even, on the PCB.
Offline _haru
« Reply #4 on: Wed, 26 July 2017, 05:08:48 »
Awesome, thanks for the info!
Offline hetvler
« Reply #5 on: Tue, 03 December 2019, 15:01:37 »
wow.  this tool is brilliant.  Is there a http://builder.swillkb.com equivalent for PCBs?
