Author Topic: [IC] GMK Blue on Black (Bob, Subtitle "Signal") - 11/12 GB opened!  (Read 92341 times)
Offline AlexAtPanc
    • Panc Interactive
Re: [IC] GMK Blue on Black (Bob, Subtitle "Signal") - 08/10 Updated
« Reply #50 on: Thu, 10 August 2017, 07:19:25 »
Yep, down with it.
Offline wylie
« Reply #51 on: Mon, 14 August 2017, 10:19:44 »
i like this keyset, it  fairly simple
Offline poolside
« Reply #52 on: Sun, 20 August 2017, 06:23:00 »
I would like to register my interest as Burgundy was a success, but the R3 Control now seems to be gone from the render :'(
If the R3 Control with the ^ icon legend can't be made, could a full-touch R3 CapsLock still be included?
So will the updated version have a blue escape with text "Esc"?
Blue esc was deleted because of add the point keycap. But not fixed yet. Still considering including or not.
Yes, please keep the blue accent "Esc".
Also, if an extra R4 | \ keycap was added, this set would fully support US international on ISO  :)
Offline cocobrais
« Reply #53 on: Sun, 20 August 2017, 06:30:51 »
capslock is 2 ea as center stem and offset stem. I think that full-touch R3 capslock means center stem capslock.
Offline breckstar
« Reply #54 on: Mon, 21 August 2017, 22:19:18 »
Icon mods. I'm in. Yuri icon mods. I'm double in.
Offline cocobrais
« Reply #55 on: Tue, 22 August 2017, 01:47:19 »
Triple in plz. :D
Offline alveeno
« Reply #56 on: Thu, 24 August 2017, 00:36:53 »
Support for N9 and icon mods!
Offline amnesia0287
  • Formerly Amnesia
« Reply #57 on: Thu, 24 August 2017, 05:09:35 »
N9 isn't black... I have a V4 on N9 key and it's really hard to read. Might as well be a blank. Ocean dolch is a much better way to go if you want N9
Offline cocobrais
Re: [IC] GMK Blue on Black (Bob, Subtitle "Signal") - 09/09 Huge Updated
« Reply #58 on: Fri, 08 September 2017, 23:10:20 »
Updated! But So sad because of expected high price :(
Offline Atredl
« Reply #59 on: Fri, 08 September 2017, 23:55:35 »
There are quite a few novelties in the base kit..
Offline amnesia0287
  • Formerly Amnesia
« Reply #60 on: Sat, 09 September 2017, 01:41:28 »
Why would this be sooo much more than Coniferous? I only see 3 new molds the esc clouds and the 2 sizes of cloud win keys. Coniferous had 173 keys and was only 150 at 150. 135 at 250.
Also if it were me I'd drop the kbd lab q and GMK keys. And then if the price was still too high the cloud win keys. The R1 esc novelty alone shouldn't raise moq THAT much. A single custom novelty key run at 150 moq is only like $5 a key. But multiples should be cheaper.
3 molds shouldn't add $25 to the price.
Offline cocobrais
« Reply #61 on: Sat, 09 September 2017, 02:39:50 »
Yes, you are right. I have to reduce the novelty keys and some keys. I will updated. And maybe I would have to add the space bar to base and delete the LED keys. It will be helpful to decrease the cost.
Offline cocobrais
Re: [IC] GMK Blue on Black (Bob, Subtitle "Signal") - 01/10 Final Updated
« Reply #62 on: Sat, 30 September 2017, 21:41:04 »
Final version was updated!
« Reply #63 on: Sat, 30 September 2017, 21:45:57 »
looks good to me
shame there's no stepped windowed caps lock, but i can see why one wouldn't want one
Offline avid
« Reply #64 on: Sat, 30 September 2017, 22:18:49 »
Beautiful colors!  :thumb: Curious if only doing the 4 necessary keys for ISO, how much does that add to price?
https://imgur.com/a/0Kap6
« Last Edit: Sat, 30 September 2017, 22:30:39 by avid »
« Reply #65 on: Sat, 30 September 2017, 22:42:42 »
GMK has raised their prices, and the euro has gotten significantly stronger recently, so even a 5 EUR increase can be pretty considerable for people buying with weaker currencies...
For example, KRW or SGD
USD banter incoming
Offline Atredl
A bit of a shame we had to loose so many keys but it looks like most compatibility is still present. I think the key I’ll miss the most is row3 control but with this being an all icon set I’ll just pretend the caps arrow means control.
Offline cocobrais
« Reply #67 on: Sat, 30 September 2017, 23:10:20 »
USD banter incomingI also expect to increase 5euro as total 5 keys(4 ISO+Blue ISO enter). I am sorry for missing ISO keys.
Offline cocobrais
Sorry for deleting many keys. But I have to consider the price......I also So sad :-[
Offline pvd
« Reply #69 on: Sat, 30 September 2017, 23:29:26 »
Looks good! Excited for this group buy.
Offline cocobrais
« Reply #70 on: Sat, 30 September 2017, 23:33:14 »
|Many Thanks!!!  ;D
Offline skizosavior
« Reply #71 on: Sun, 01 October 2017, 01:57:03 »
I want it, I need it, and I would absolutely get it. I love the use of VR instead of N9, the additional contrast is great imo. Would like to see barred F/J, as well as text icons, but understand that its personal preference, either way I think its amazing!
Offline aznreaper
« Reply #72 on: Sun, 01 October 2017, 02:46:28 »
Oh exciting, I'm glad to see this finalized, when are you thinking about starting the buy for this one?
Offline cocobrais
« Reply #73 on: Sun, 01 October 2017, 03:47:06 »
Thanks and if progress, join this! ;D
Offline cocobrais
« Reply #74 on: Sun, 01 October 2017, 03:49:07 »
I don't know exactly. But if many members are interesting, meetnthis soon.
Offline Vigrith
« Reply #75 on: Sun, 01 October 2017, 12:01:35 »
Lovely use of full icon mods.
Offline kmba
  • Formerly tameone
« Reply #76 on: Sun, 01 October 2017, 13:14:24 »
Personally I think you can drop the novelties all together and lower price a bit more, or add in iso support.
keyboards.
Offline Atredl
« Reply #77 on: Sun, 01 October 2017, 13:17:52 »
It would make sense to do a swap of novelties for ISO. Novelties don't add compatibility for anyone while ISO will.
Offline ideus
  • Björkö.
« Reply #78 on: Sun, 01 October 2017, 14:49:16 »
Dropping the ISO is understandable if the set gets a good pricing. The inclusion of the icon modifiers makes this interesting. What it is a very unfortunate decision is the lack of a six units off-centered space bar.
Offline cocobrais
« Reply #79 on: Tue, 03 October 2017, 05:26:30 »
Final update will be done. Wait reallyx5 final update. :D
Offline cocobrais
Relly final version was updated.
I hope that this version will be satisfied for many guys.  ;D
Offline bkw1209
Oh no..
 Novelty key.... :-[ :-[ :-[ :-[
Offline cocobrais
Oh no..
I also sad. But this decision is to decrease the cost and add other keys.
Offline poolside
This looks good to me  :thumb:
Offline avid
Nice on cocobrais!  :thumb:
Is there any estimate when this is going to run? I really like the blue + black combination.
Offline cocobrais
Offline cocobrais
Soon..I hope...but in my expectation, I have to find the proxy out of Korea because of exchange rate. If I will progress own control, it will be high price.  :(
Offline ideus
  • Björkö.
The set is a first that put a full icon mod to good use and in an elegant color, nothing better.
It requires an icon Esc key, either replacing the standard one, or additional.
« Last Edit: Sat, 14 October 2017, 08:09:27 by ideus »
Offline ojrask
  • juuh elikkäs
Just posting to get updates and to show support. Looks good. A nice change from the more complex sets that have run recently.
Current:
Coming up:
IC/GB:
Offline uniqueskull
I like that!
I'm in! ;)
This is a winner. I'm in.
Offline poolside
Nice to see ISO and G80-1800 bottom row come back  :thumb:
Could the numpad pad printed side legends be changed to doubleshot on the top? I had never seen these numpad side prints until today, and they unfortunately look very cheap. It's even worse than the "SysReq" and "Break" pad prints usually featured on the Scroll Lock and Pause keycaps.
Offline ideus
  • Björkö.
+1, double shot any time. And the 1800 bottom row come with icons, yummy.
Offline digi
  • elite af tbh
  • keyboard game on fleek
So simple, yet so good...must...resist...ugh
Offline txclack
So many good sets dropping at once.  This one is a 'must have' in my opinion.
Offline cocobrais
Side printing was used in 9009 R1. This is just my concept for this set. As you know, I delete the novelty keys to satisfy many request. Maybe side printing is only remained for my concept. I hope your understanding.  :D
Offline ideus
  • Björkö.
One more time, this is missing. Either black or blue, or both.
Offline Atredl
I'm a fan of the side printing. Please keep it  :D
Offline amnesia0287
  • Formerly Amnesia
I think he’s asking if they can doubleshot the top legend and only print the front legend.
Offline cocobrais
I hope so ;D
