Author Topic: KBD66 ported to QMK  (Read 3045 times)
Offline judy2k
KBD66 ported to QMK
« on: Mon, 31 July 2017, 03:00:51 »
I recently received my KBDFans KBD66 from Massdrop, and I love it! But it runs TMK, and my Planck runs QMK. I thought it would be nice to run the same firmware on both, and I wanted to try out some neat QMK features like space cadet shift keys.
So, anyway, I have a fork of QMK with the kbd66 firmware added. It has support for Qwerty (Fn-Q) and Dvorak (Fn-W), and can switch Alt & Gui keys for OSX support (Fn-A) and (Fn-S).
Current limitation is that it's currently just ISO layout. It should be relatively easy to add ANSI if you've used a different layout for your kbd664. I didn't want to add ANSI right now because I have no way to test it.
I plan to submit this to the original QMK repo. I just need to tidy it up a little bit, document it, and open a PR. If anyone would like to try it out in the meantime though, any feedback would be gratefully received!
You can clone the code from here: https://github.com/judy2k/qmk_firmware/tree/kbd66 (note the kbd66 keymap is on the kbd66 branch).
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
Re: KBD66 ported to QMK
« Reply #1 on: Mon, 31 July 2017, 18:42:33 »
Just thought I'd let you know: the PCB the KBD66 uses is actually a Team AMJ product, called the AMJ66. So I think your work would be easier for more users to find if you renames it as above ;)
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline judy2k
« Reply #2 on: Tue, 01 August 2017, 13:05:42 »
Hey thanks! I'll add it to the title.
I did know the PCB said AMJ66 on it, but honestly I'm relatively new to all this keyboard stuff, and I just wanted my keyboard on QMK (I'm not new to software) :-)
Offline judy2k
Re: AMJ66 ported to QMK
« Reply #3 on: Tue, 01 August 2017, 13:07:29 »
Maybe I won't change the title - I don't seem to have the ability to do that :-)
