Author Topic: Keyboard Recommendation  (Read 2318 times)
Offline jp7189
« on: Thu, 03 August 2017, 16:37:15 »
I've been looking for the perfect mechanical keyboard, but I haven't found it yet. I've been searching the web, and contacting resellers and manufacturers, and one of them pointed me here.
I'm currently using a Logitech K800, and has all the things I'm looking for, but it's a bit mushy on the feel, and I'd like to get a real mechanical keyboard.
Here are my requirements:
1. Wireless
2. Backlit
3. Short throw keys (like Cherry MX Silver or similar)
4. Optional: number pad - if this were a separate piece that would be fine too.
Where I work and game, the PC is in a different room, and I work off a projection screen.  That's the main reason for the wireless requirement (unless I want to run a USB extension cable across the floor and out the door).  It's the wireless requirement that's causing me the most grief.
It would be great if my dream keyboard were already a reality (and I just don't know it yet), but I'm not above hacking the mechanicals from one keyboard with the electronics of another to get what I want.
Thoughts?
Offline Tactile
Re: Keyboard Recommendation
« Reply #1 on: Thu, 03 August 2017, 16:52:20 »
Two mis-posts in two days. I'm going outside...
« Last Edit: Thu, 03 August 2017, 16:56:31 by Tactile »
REΛLFORCE
Offline Cotay
« Reply #2 on: Sat, 05 August 2017, 12:06:37 »
1. Wireless
2. Backlit
Thoughts?
Check out the Varmilo VB87M. Bluetooth 4.0 with MX Speed Silver option. It can be customized and ordered directly from Varmilo: http://en.varmilo.com/
Offline SBJ
  • Tactile pls
« Reply #3 on: Sun, 06 August 2017, 02:57:58 »
Wow, there are plenty of customization options via the website now.
That's fantastic.
