Author Topic: Recommended Lube for Cherry Stabilizers  (Read 29404 times)
Offline benjafull
« on: Sat, 05 August 2017, 02:14:13 »
Hello !
What type of lube can i use on my cherry stabilizers ( especially spacebar).
some say lithium Grease is the default manufacturer choice, but i read in some places that it damages some plastics....  :rolleyes:
can i use silicone lubricant ? but in spray ??
or solid vaseline or engine oil ??
the litium grease in spray damage plastics ?
thanks :D
Offline need
Re: Recommended Lube for Cherry Stabilizers
« Reply #1 on: Sat, 05 August 2017, 04:40:03 »
Silicone grease works really well. They are safe to eat so I assume they are safe on plastics.
Offline pr0ximity
« Reply #2 on: Sat, 05 August 2017, 06:20:28 »
iirc vaseline will damage plastic so maybe stay away from that..
Offline Leslieann
« Reply #3 on: Sat, 05 August 2017, 06:38:52 »
Vaseline is petroleum jelly, which is based on petroleum (oil). It will eat your switches.
Lithium should be safe. Silicone is safe. Synthetic can be anything.
Whatever you use, you want to make sure it says on it that it's safe for plastics. Just because it's based on something safe doesn't mean there isn't anything added to it that won't attack plastics.
If you can't be sure something is safe, don't use it. Go to a hobby shop with an RC car section (or website) and get some there. Almost anything used on an rc car needs to be plastic safe. Diff lube works well on stabilizers, it's what is on my Filco and it has lasted a long time.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline pixelpusher
« Reply #4 on: Sat, 05 August 2017, 08:11:37 »
Offline benjafull
« Reply #5 on: Sat, 05 August 2017, 15:46:14 »
Thanks for all the answers  :thumb:
I walked in all shops arround my city, and the only thing I found was this:
Will work ??
http://imgur.com/a/7IyNa
« Last Edit: Sat, 05 August 2017, 15:47:55 by benjafull »
Offline pixelpusher
« Reply #6 on: Sat, 05 August 2017, 16:03:37 »
Isn't that spray?  You want a thick grease substance for stabilizers
Offline benjafull
« Reply #7 on: Sat, 05 August 2017, 16:21:46 »
yes, is spray, i dont fount thick grease and not damage plastic :/
Offline Leslieann
« Reply #8 on: Sat, 05 August 2017, 16:40:48 »
You really want something thicker for stabs, and you certainly don't want to spray onto the keyboard.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline benjafull
« Reply #9 on: Sat, 05 August 2017, 21:54:29 »
could work the  "bel ray food grease 1 " ????????
 it is used in machinery that is in contact with food... :confused:
Offline jcoffin1981
« Reply #10 on: Sat, 05 August 2017, 22:40:14 »
dielectric grease
