Author Topic: Vortex Core Firmware update changed Caps key  (Read 3126 times)
Offline Severe
  • HHKB Zealot
« on: Sat, 12 August 2017, 00:55:27 »
Before the update I had the caps lock key programmed on all my layers to be the tab key. It seems that after updating the firmware to Vers. 1.04.03 The Caps key is now standard as the Tab key and its Fn function is caps lock. even on the primary layer you can't reprogram.
Has anyone else noticed this?
HHKB Pro 2 Black Lubed 55g
Logitech G502 (Gaming) Logitech MX Master 2 (Day to day)
Offline daerid
    • Rossipedia
Re: Vortex Core Firmware update changed Caps key
« Reply #1 on: Sat, 12 August 2017, 11:21:51 »
Inability to reprogram keys is a deal-breaker. Shame, I was really looking forward to getting a Core :(
Offline Severe
  • HHKB Zealot
« Reply #2 on: Sat, 12 August 2017, 12:12:48 »
There are 3 reprogramamble layers. just layer zero isn't
