Author Topic: Opening IBM KB-8923  (Read 11143 times)
Offline EverythingIBM
Opening IBM KB-8923
« on: Fri, 12 March 2010, 23:31:42 »
I have two IBM KB-8923 keyboards, the best possible quality pure rubber dome you can get, and I can't open them!
I unscrewed all the screws, but, if I pull one side; the other side gets stuck down, and vice versa. These things don't even NEED screws to hold them together. Unlike the more pronounced "lip" on the bottom of Model Ms, these sink down, so, you really have to dig your nails to pull the bottom up; which is why the sides are kind of easier.
I'm trying to open my first one, since, it's VERY dirty (it was the keyboard I used all the time for everything for 13 years). I pulled out all the keys usually to clean it, but, I want to take it all apart, and clean every inch.
Heh, the arrow keys on it are so worn out, that, even the labelling is coming off very slightly, and, you can rotate them in circular motion. I played every single game I own on those arrow keys, so, that's pretty good. NONE of the labels otherwise have worn off, which is absolutely amazing. I typed laods on that keyboard.
If you want keys that will never wear out, use KB-8923 key stems.
Offline JBert
Opening IBM KB-8923
« Reply #1 on: Sat, 13 March 2010, 03:24:51 »
Ah yes, I still have a couple of those.
In fact, your problem is that IBM "overengineered" this rubber-dome keyboard. It has actually 12 screws to keep it closed, not just the 8 you can see.
To get to those screws, pop off the following keys:
Q, A, Y, H, [, ", Numpad 8, Numpad 5
Use any key extractor you like. I used a wooden popsicle stick to pry them loose.
Once you unscrew those, the keyboard just falls open, allowing you to gaze at the sheet of rubber and its membrane beneath.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline spolia optima
Opening IBM KB-8923
« Reply #2 on: Sat, 13 March 2010, 05:34:15 »
Quote from: webwit;163609
I love IBM boards, but this is clearly a keyboard from hell. I had to ceremoniously destroy it.
You destroy keyboards too? Small world. I threw a sun type 3 off the back of a ferry last summer. That's not even a joke.
I keep a whole stack of keyboards for target practice. It's great stress relief.
keyboards!
Offline ch_123
Opening IBM KB-8923
« Reply #3 on: Sat, 13 March 2010, 05:49:16 »
For bonus awesome points, you should have used it as a clay pigeon.
How good/not good where those Type 3s anyway? They look like foam'n'foil keyboards as far as I can see.
Offline JBert
Opening IBM KB-8923
« Reply #4 on: Sat, 13 March 2010, 07:14:26 »
The thing is, for a keyboard from hell, IBM did it well.
The storage list:
[/SIZE]
Offline TexasFlood
Opening IBM KB-8923
« Reply #5 on: Sat, 13 March 2010, 07:51:03 »
You don't still have the trackpoint from it, do you? My KB8923 is fine but the trackpoint got stepped on by one of my kids and got destroyed.
Offline ricercar
  • mostly abides
Opening IBM KB-8923
« Reply #6 on: Sat, 13 March 2010, 10:57:47 »
Quote from: spolia optima;163624
Once I dropped a payphone off a bridge. Payphones have keypads. Does that count?
Opening IBM KB-8923
« Reply #7 on: Sat, 13 March 2010, 11:33:28 »
Quote from: JBert;163601
That's cool! Thanks!
Hopefully I didn't wreck it trying to pry it open. But wrecking one of these would require a lot more than bending the bezel.
The funny thing is, these actually have metal in the back too when I was peeking with the limited space I had.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Opening IBM KB-8923
« Reply #8 on: Sat, 13 March 2010, 14:21:45 »
For key removing, I  like to use one of those metal things that patches up a PCI or ISA slot. It's easy to wedge right under the key and pry it up without scratching the outside.
Opening IBM KB-8923
« Reply #9 on: Sat, 13 March 2010, 16:13:52 »
Quote from: microsoft windows;163754
I use an advanced piece of technology called a "butter knife".
And... after you're done opening some IBM keyboards with your butter knife, you can dine at IBM; so your butter knife will have a multi-purpose:
Offline itlnstln
Opening IBM KB-8923
« Reply #10 on: Mon, 15 March 2010, 07:50:19 »
Quote from: ricercar;163705
Were there any coins in the return slot, Dobie?
Offline kriminal
Opening IBM KB-8923
« Reply #11 on: Mon, 15 March 2010, 08:34:11 »
im against littering....
however using rubberdomes as clay pigeons - priceless
Geekhacked Filco FKBN87M/EB modified with Brown, black and blue cherries, doubleshot keycaps
Deck KBA-BL82 with Black cherries
Cherry G84-4100LCMDK-0 Cherry ML switches
Cherry G80-8200hpdus-2 Brown cherries
IBM Lexmark 51G8572 Model M Keyboard
Geekhacked Siig Minitouch KB1948
IBM Model M Mini 1397681
Offline ricercar
  • mostly abides
Opening IBM KB-8923
« Reply #12 on: Mon, 15 March 2010, 18:57:02 »
Quote from: itlnstln;164146
No, but there was a hole in the coin box about as deep as 3 diamond-tipped bits would get. (Not very.)
Offline captain
Opening IBM KB-8923
« Reply #13 on: Mon, 19 March 2012, 22:47:20 »
what about Wyse KB-8923?  Same thing?
Welcome to geekhack -- where we like to type -- but don't care so much about reading.
